Polaroid P902 LCD and Digitizer Replacement
    1. Polaroid P902 LCD and Digitizer  Replacement, The Tools: step 1, image 1 of 3 Polaroid P902 LCD and Digitizer  Replacement, The Tools: step 1, image 2 of 3 Polaroid P902 LCD and Digitizer  Replacement, The Tools: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • The most important part of any repair is the tools used. Here's what I brought to this repair. Xool 58 in 1 Precision Screwdriver Set, DREMINOVA Heat soldering Mat Large Pad, and Xool 10pc EDS Anti-Static tweezers. I also always wear gloves when preforming repairs, my preferred gloves are Grease Monkey Disposable Nitrile Gloves.
      Ask FixBot
    2. Polaroid P902 LCD and Digitizer  Replacement, The Back: step 2, image 1 of 3 Polaroid P902 LCD and Digitizer  Replacement, The Back: step 2, image 2 of 3 Polaroid P902 LCD and Digitizer  Replacement, The Back: step 2, image 3 of 3
      • First remove the two screws circled in the first picture with a PH00 bit.
      • After the screws have been removed take a plastic spudger and use it to lift the LCD from the backing
      • You will have to use some force don't be scared of it.
      Ask FixBot
    3. Polaroid P902 LCD and Digitizer  Replacement, Ribbons: step 3, image 1 of 3 Polaroid P902 LCD and Digitizer  Replacement, Ribbons: step 3, image 2 of 3 Polaroid P902 LCD and Digitizer  Replacement, Ribbons: step 3, image 3 of 3
      • Next using the flat end of a plastic spudger release the clips holding the ribbon circled in the first picture.
      Ask FixBot
    4. Polaroid P902 LCD and Digitizer  Replacement, The Screws: step 4, image 1 of 2 Polaroid P902 LCD and Digitizer  Replacement, The Screws: step 4, image 2 of 2
      • Next switching to a PH000bit remove the 4 screws circled in the first picture holding the motherboard down.
      • Now remove the four screw circled in the second picture along with their plastic components.
      • Be careful when removing the plastic part holding the speaker in so as not to rip the speaker wire
      Ask FixBot
    5. Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: step 5, image 1 of 3 Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: step 5, image 2 of 3 Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: step 5, image 3 of 3
      • Flip the tablet over gently, then applying slight pressure on the left hand side lift the digitizer from the LCD
      • it should just lift right off. However you may need to do a bit of wiggling. Don't stress if it doesn't drop right off.
      Ask FixBot
    6. Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: step 6, image 1 of 3 Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: step 6, image 2 of 3 Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: step 6, image 3 of 3
      • Now go around the edges of the metal and release the metal tabs holding the LCD in place
      • I used an iSesamo to do this, made it super easy
      • On the left side of the LCD screen after removing the top metal plate you will see a strip of adhesive, remove it and your almost done
      Ask FixBot
    7. Polaroid P902 LCD and Digitizer  Replacement, FINALLY!!: step 7, image 1 of 2 Polaroid P902 LCD and Digitizer  Replacement, FINALLY!!: step 7, image 2 of 2
      • Now lift the LCD straight up and out of the bottom casing and you're halfway through the repair :D
      • Now insert the new LCD and reverse the steps. Pat yourself on the back o grab some snacks and check out your like new tablet.
      Ask FixBot
Aj Jones
1 Reputation
1 Guide authored
Loading.. Game Repairs Member of Loading.. Game Repairs
Business
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 526
