Polaroid Onestep Close Up Shutter Switch Replacement
  1. Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: step 1, image 1 of 3 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: step 1, image 2 of 3 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: step 1, image 3 of 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
    Ask FixBot
  2. Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: step 2, image 1 of 2 Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: step 2, image 2 of 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
    Ask FixBot
  3. Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: step 3, image 1 of 3 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: step 3, image 2 of 3 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: step 3, image 3 of 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
    Ask FixBot
  4. Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: step 4, image 1 of 3 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: step 4, image 2 of 3 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: step 4, image 3 of 3
    • After the face plate is off, the shutter switch should slide out easily.
    Ask FixBot
3 other people completed this guide.
Tyler OBrien
627 Reputation
2 Guides authored
USF Tampa, Team 3-5, Brown Fall 2014 Member of USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Members
6 Guides authored
2 Guide Comments
where did you get the replacement parts for this?
Jacob Sokolove - Reply Share
I’d love to find a new shutter piece..
Joni Korkkula - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 46
All Time: 4,963
