Up to 20% off select tools
Polaroid OneStep 2 Shutter Switch Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
86
All Time:
2,727
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you need to replace the shutter switch, use this guide to access the inside of the camera. You may need to replace the shutter switch if your shutter is not firing and your camera is not taking photos.
    1. Polaroid OneStep 2 Shutter Switch Replacement, Shutter Switch: step 1, image 1 of 3 Polaroid OneStep 2 Shutter Switch Replacement, Shutter Switch: step 1, image 2 of 3 Polaroid OneStep 2 Shutter Switch Replacement, Shutter Switch: step 1, image 3 of 3
      • Remove the four 5mm screws on the base of the camera using a Phillips #0 screwdriver.
      • Remove the two pieces of the base.
      Ask FixBot
    2. Polaroid OneStep 2 Shutter Switch Replacement: step 2, image 1 of 3 Polaroid OneStep 2 Shutter Switch Replacement: step 2, image 2 of 3 Polaroid OneStep 2 Shutter Switch Replacement: step 2, image 3 of 3
      • Remove the four 5mm screws on the top of the inside base piece using a Phillips #0 screwdriver.
      • Remove the two 5mm screws on the bottom of the inside base piece which is near the strap with the same screwdriver.
      Ask FixBot
    3. Polaroid OneStep 2 Shutter Switch Replacement: step 3, image 1 of 1
      • Remove the black inside base piece.
      Ask FixBot
    4. Polaroid OneStep 2 Shutter Switch Replacement: step 4, image 1 of 2 Polaroid OneStep 2 Shutter Switch Replacement: step 4, image 2 of 2
      • With force separate the white front piece from the back of the camera. You will use your hands and pull it apart.
      Ask FixBot
    5. Polaroid OneStep 2 Shutter Switch Replacement: step 5, image 1 of 2 Polaroid OneStep 2 Shutter Switch Replacement: step 5, image 2 of 2
      • With force pull the shutter button away from the white piece of the camera.
      Ask FixBot
4 other people completed this guide.
Author
with
Abby Boucher
841 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 86
All Time: 2,727
