Polaroid I-2 USB-C Port Board Replacement
  1. Polaroid I-2 USB-C Port Board Replacement, Safety information: step 1, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Safety information: step 1, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Safety information: step 1, image 3 of 3
    • If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
    • Before you begin:
    • Power down and unplug your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid I-2 USB-C Port Board Replacement, Open the film door: step 2, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement, Open the film door: step 2, image 2 of 2
    • In the following steps, "left" and "right" are written from the perspective of using the camera—or when the lens is facing away from you.
    • Use the latch on the left side of the camera to open the film door.
  3. Polaroid I-2 USB-C Port Board Replacement, Insert a blocker: step 3, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Insert a blocker: step 3, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Insert a blocker: step 3, image 3 of 3
    • Fold a piece of cloth or napkin (or the included bag) into a small square.
    • Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
  4. Polaroid I-2 USB-C Port Board Replacement, Flip the camera over: step 4, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Flip the camera over: step 4, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Flip the camera over: step 4, image 3 of 3
    • Flip the camera over, making sure the cloth stays lodged in the film compartment.
  5. Polaroid I-2 USB-C Port Board Replacement, Unfasten the bottom cover: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
  6. Polaroid I-2 USB-C Port Board Replacement, Unclip the bottom cover: step 6, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Unclip the bottom cover: step 6, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Unclip the bottom cover: step 6, image 3 of 3
    • Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
    • Tilt the pick up and push to position the pick between the bottom and front covers.
  7. Polaroid I-2 USB-C Port Board Replacement: step 7, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement: step 7, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement: step 7, image 3 of 3
    • Slide the opening pick toward the rear of the camera to release the clips along the left edge.
    • Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
  8. Polaroid I-2 USB-C Port Board Replacement: step 8, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement: step 8, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement: step 8, image 3 of 3
    • Insert the tip of a second opening pick under the top right corner of the bottom cover.
  9. Polaroid I-2 USB-C Port Board Replacement: step 9, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement: step 9, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement: step 9, image 3 of 3
    • Slide the opening pick toward the rear of the camera to release the clips along the right edge.
  10. Polaroid I-2 USB-C Port Board Replacement, Remove the bottom cover: step 10, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Remove the bottom cover: step 10, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Remove the bottom cover: step 10, image 3 of 3
    • At this point, the bottom cover clips should be released. If not, slide an opening pick along the perimeter of the back cover to release any remaining clips.
    • Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
    • Remove the back cover.
    • During reassembly, insert the film door lever into its recess before aligning the bottom cover and pressing it into place to secure its clips.
  11. Polaroid I-2 USB-C Port Board Replacement, Disconnect the film door: step 11, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Disconnect the film door: step 11, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Disconnect the film door: step 11, image 3 of 3
    • Insert the flat end of a spudger between the film door's left hinge and the frame.
    • Twist the spudger to separate the rubber hinge grommet from its peg in the frame.
    • Pull the film door towards the front of the camera to completely disconnect its left hinge.
  12. Polaroid I-2 USB-C Port Board Replacement: step 12, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement: step 12, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement: step 12, image 3 of 3
    • Tilt the left edge of the film door up to separate the left hinge's rubber grommet.
    • Remove the film door.
    • At this point, you can remove the cloth blocker from under the print roller.
    • During reassembly, hook the left hinge on its post and push the right hinge over its post until it snaps into place.
  13. Polaroid I-2 USB-C Port Board Replacement, Unfasten the back cover: step 13, image 1 of 1
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the back cover.
  14. Polaroid I-2 USB-C Port Board Replacement, Unclip the back cover: step 14, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Unclip the back cover: step 14, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Unclip the back cover: step 14, image 3 of 3
    • There are two alignment pegs along the bottom edge of the back cover.
    • Insert a spudger between the frame and the alignment hole on the back cover.
    • Twist the spudger to lift the back cover off of the alignment peg.
    • Repeat for the second alignment peg.
  15. Polaroid I-2 USB-C Port Board Replacement, Disassembly information: step 15, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Disassembly information: step 15, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Disassembly information: step 15, image 3 of 3
    • There are eight large clips that secure the back cover. The next four steps show how to release them.
    • These clips are very strong and require significant force to release.
    • The procedure to release the clips is tricky and will require time and patience to perform correctly.
  16. Polaroid I-2 USB-C Port Board Replacement, Insert an opening pick: step 16, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Insert an opening pick: step 16, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Insert an opening pick: step 16, image 3 of 3
    • Releasing the clips requires getting a tool between the covered "thin" edge of the front cover and the clips themselves.
    • Angle an opening pick upward and insert it at the gap where the bottom right corner of the back cover meets the triangular tip of the front cover’s right edge.
    • Push the pick up to get it above the overhanging lip in the back cover.
    • You'll see the plastic warp a little. This is normal.
    • While pushing upward, slowly rotate the pick towards the left edge of the camera until it's under the front cover.
    • The pick can slip out easily, so this may take a few tries.
  17. Polaroid I-2 USB-C Port Board Replacement: step 17, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement: step 17, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement: step 17, image 3 of 3
    • While pushing the pick downward, slide it all the way up the right edge to release the clips.
    • Keep the pick as upright as possible while sliding to avoid hitting the clips.
    • The plastic in the lip of the back cover will warp. This is normal.
    • Leave the pick at the top corner before continuing to prevent the clips from resecuring.
  18. Polaroid I-2 USB-C Port Board Replacement: step 18, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement: step 18, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement: step 18, image 3 of 3
    • Angle a second opening pick upward and insert it at the gap where the bottom left corner of the back cover meets the triangular tip of the front cover’s left edge.
    • While pushing upward, slowly rotate the pick towards the right edge of the camera until it's under the front cover.
  19. Polaroid I-2 USB-C Port Board Replacement: step 19, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement: step 19, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement: step 19, image 3 of 3
    • While pushing the pick downward, slide it all the way up the left edge to release the remaining clips.
  20. Polaroid I-2 USB-C Port Board Replacement, Reposition the back cover: step 20, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Reposition the back cover: step 20, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Reposition the back cover: step 20, image 3 of 3
    • Don't try to pull the back cover off just yet, as it's still connected by a cable.
    • At this point, the back cover should feel loose. If any parts still feel connected, repeat the last four steps until all the clips release.
    • Pull the back cover off the camera and rotate it over the right edge to expose the flex cable.
    • During reassembly, make sure the the flex cable isn't caught between the covers before re‑engaging the clips.
  21. Polaroid I-2 USB-C Port Board Replacement, Remove the tape: step 21, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Remove the tape: step 21, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Remove the tape: step 21, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to peel off the tape covering the interconnect cable ZIF connector on the control board.
    • Set the tape aside. You'll reuse it during reassembly.
  22. Polaroid I-2 USB-C Port Board Replacement, Disconnect the control board: step 22, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement, Disconnect the control board: step 22, image 2 of 2
    • Use the flat end of a spudger to lift up the locking flap on the control board ZIF connector.
  23. Polaroid I-2 USB-C Port Board Replacement: step 23, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement: step 23, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement: step 23, image 3 of 3
    • Use tweezers to pull the interconnect cable out of its slot in the control board.
  24. Polaroid I-2 USB-C Port Board Replacement, Unfasten the top cover: step 24, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Unfasten the top cover: step 24, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Unfasten the top cover: step 24, image 3 of 3
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the top cover.
  25. Polaroid I-2 USB-C Port Board Replacement, Unclip the top cover: step 25, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement, Unclip the top cover: step 25, image 2 of 2
    • The next six steps demonstrate how to release the top cover's clips. These clips can re-engage easily, so you may need to repeat certain steps to release all of the clips.
    • Angle an opening pick upward and insert in the gap at the top right corner of the top cover and front cover, next to the flash.
  26. Polaroid I-2 USB-C Port Board Replacement: step 26, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement: step 26, image 2 of 2
    • Leave the pick in the gap before continuing to prevent the clips from re‑engaging.
  27. Polaroid I-2 USB-C Port Board Replacement: step 27, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement: step 27, image 2 of 2
    • Angle a second opening pick upward and insert in the gap at the top left corner of the top cover and front cover.
  28. Polaroid I-2 USB-C Port Board Replacement: step 28, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement: step 28, image 2 of 2
    • Leave the pick in the gap before continuing to prevent the clips from re-engaging.
  29. Polaroid I-2 USB-C Port Board Replacement: step 29, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement: step 29, image 2 of 2
    • Insert the flat end of a spudger between the frame and the top cover's left external clip, above the viewfinder.
    • Twist the spudger to release the clip.
    • If one of the opening picks fall out, don't worry! Continue with the guide as normal.
  30. Polaroid I-2 USB-C Port Board Replacement: step 30, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement: step 30, image 2 of 2
    • Insert the tip of an opening pick between the frame and the top cover's right external clip.
    • Pry up to release the clip.
  31. Polaroid I-2 USB-C Port Board Replacement, Remove the lens cap: step 31, image 1 of 1
    • Pull the lens cap off and remove it.
  32. Polaroid I-2 USB-C Port Board Replacement, Remove the top cover: step 32, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement, Remove the top cover: step 32, image 2 of 2
    • Lift the top cover off the camera and remove it.
    • During reassembly, push the top cover onto the frame until the clips re-engage.
  33. Polaroid I-2 USB-C Port Board Replacement, Disconnect the USB-C port board: step 33, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Disconnect the USB-C port board: step 33, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Disconnect the USB-C port board: step 33, image 3 of 3
    • Use the tip of a spudger to lift up the two sides of the locking tab on the USB‑C port board cable connector.
  34. Polaroid I-2 USB-C Port Board Replacement: step 34, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement: step 34, image 2 of 2
    Buy
    • Use tweezers to pull the USB-C port board cable connector out of its socket.
  35. Polaroid I-2 USB-C Port Board Replacement, Unfasten the front cover: step 35, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement, Unfasten the front cover: step 35, image 2 of 2
    • Use a Phillips screwdriver to remove the four screws securing the front cover:
    • Two 5.9 mm-long screws along the back edge of the front cover
    • Flip your camera over.
    • Two 3.9 mm-long screws under the front of the camera
  36. Polaroid I-2 USB-C Port Board Replacement, Reposition the front cover: step 36, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement, Reposition the front cover: step 36, image 2 of 2
    • Lift the back edge of the front cover up enough for the USB-C port board to slide underneath it.
  37. Polaroid I-2 USB-C Port Board Replacement, Remove the USB-C port: step 37, image 1 of 2 Polaroid I-2 USB-C Port Board Replacement, Remove the USB-C port: step 37, image 2 of 2
    • Pull the USB-C port board straight out of its slot in the frame and remove it.
    • During reassembly, align the board properly in its slot in the frame before sliding back into place.
  38. Polaroid I-2 USB-C Port Board Replacement, Remove the plastic cover: step 38, image 1 of 3 Polaroid I-2 USB-C Port Board Replacement, Remove the plastic cover: step 38, image 2 of 3 Polaroid I-2 USB-C Port Board Replacement, Remove the plastic cover: step 38, image 3 of 3
    • The plastic cover is secured to the USB‑C port board with an alignment peg.
    • Insert the flat end of a spudger between the plastic cover and the top of the USB-C port board, above the 2.5 mm jack.
    • Twist the spudger to lift the alignment peg out of its slot in the board.
    • Pull the plastic cover off the USB-C port board.
    • Only the USB‑C port board remains.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
Alex Diaz-Kokaisl
237,548 Reputation
1,171 Guides authored
iFixit Member of iFixit
Staff
123 Members
25,686 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 67
All Time: 729
