Introduction
Use this guide to replace a torn or stuck film shield (the black film that covers a newly-pressed photo, aka frog tongue) in your Polaroid I-2 camera.
This guide involves partial disassembly of the print roller. The print roller is a critical component responsible for evenly spreading the reagent chemical across the film when developing photos. When removing the print roller, be very careful not to bend or warp the metal to ensure the camera works properly after reassembly.
If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
Before you begin:
Power down and unplug your camera.
Put on the lens cap to avoid scratching your lens during disassembly.
Fold a piece of cloth or napkin (or the included bag) into a small square.
Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
Flip the camera over, making sure the cloth stays lodged in the film compartment.
Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
Tilt the pick up and push to position the pick between the bottom and front covers.
Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
Remove the back cover.
Insert the flat end of a spudger between the film door's left hinge and the frame.
Twist the spudger to separate the rubber hinge grommet from its peg in the frame.
Pull the film door towards the front of the camera to completely disconnect its left hinge.
Use a Phillips screwdriver to remove the 3.9 mm-long screw securing the print roller.
Use the tip of a spudger to depress both the plastic tabs until their hooks release from the print roller.
Grab the print roller by one of its arms and pull it straight out of its plastic housing.
There are two metal L-shaped rails at the bottom of the print roller that have to slide under cutouts in the plastic housing.
There are two metal hooks at the top of the print roller that have to fit under the top corners of the plastic housing.
Insert the print roller at a downward angle to fit the hooks in first before sliding the rails into place.
Push the print roller into its plastic housing until you hear the plastic tabs click back into place.
Insert the tip of an opening pick straight down into the gap between the bottom right corner of the film shield tray and the plastic housing.
Push the pick downward and pry upward to get the pick between the film shield tray and the plastic housing.
Slide the pick toward the left edge of the plastic housing to release the two clips.
Tool used on this step:Tweezers$4.99
The film shield sits on four alignment pegs.
Use tweezers to pull the film shield off its alignment pegs.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
