Polaroid I-2 Battery Replacement
    1. Polaroid I-2 Battery Replacement, Safety information: step 1, image 1 of 3 Polaroid I-2 Battery Replacement, Safety information: step 1, image 2 of 3 Polaroid I-2 Battery Replacement, Safety information: step 1, image 3 of 3
      • If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
      • Before you begin:
      • Power down and unplug your camera.
      • Put on the lens cap to avoid scratching your lens during disassembly.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Open the film door: step 2, image 1 of 2 Polaroid I-2 Battery Replacement, Open the film door: step 2, image 2 of 2
      • In the following steps, "left" and "right" are written from the perspective of using the camera—or when the lens is facing away from you.
      • Use the latch on the left side of the camera to open the film door.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement, Insert a blocker: step 3, image 1 of 3 Polaroid I-2 Battery Replacement, Insert a blocker: step 3, image 2 of 3 Polaroid I-2 Battery Replacement, Insert a blocker: step 3, image 3 of 3
      • Fold a piece of cloth or napkin (or the included bag) into a small square.
      • Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
      Ask FixBot
    3. Polaroid I-2 Battery Replacement, Flip the camera over: step 4, image 1 of 3 Polaroid I-2 Battery Replacement, Flip the camera over: step 4, image 2 of 3 Polaroid I-2 Battery Replacement, Flip the camera over: step 4, image 3 of 3
      • Flip the camera over, making sure the cloth stays lodged in the film compartment.
      Ask FixBot
    4. Polaroid I-2 Battery Replacement, Unfasten the bottom cover: step 5, image 1 of 1
      • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
      Ask FixBot
    5. Polaroid I-2 Battery Replacement, Unclip the bottom cover: step 6, image 1 of 3 Polaroid I-2 Battery Replacement, Unclip the bottom cover: step 6, image 2 of 3 Polaroid I-2 Battery Replacement, Unclip the bottom cover: step 6, image 3 of 3
      • Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
      • Tilt the pick up and push to position the pick between the bottom and front covers.
      Ask FixBot
    6. Polaroid I-2 Battery Replacement: step 7, image 1 of 3 Polaroid I-2 Battery Replacement: step 7, image 2 of 3 Polaroid I-2 Battery Replacement: step 7, image 3 of 3
      • Slide the opening pick toward the rear of the camera to release the clips along the left edge.
      • Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
      Ask FixBot
    7. Polaroid I-2 Battery Replacement: step 8, image 1 of 3 Polaroid I-2 Battery Replacement: step 8, image 2 of 3 Polaroid I-2 Battery Replacement: step 8, image 3 of 3
      • Insert the tip of a second opening pick under the top right corner of the bottom cover.
      Ask FixBot
    8. Polaroid I-2 Battery Replacement: step 9, image 1 of 3 Polaroid I-2 Battery Replacement: step 9, image 2 of 3 Polaroid I-2 Battery Replacement: step 9, image 3 of 3
      • Slide the opening pick toward the rear of the camera to release the clips along the right edge.
      Ask FixBot
    9. Polaroid I-2 Battery Replacement, Remove the bottom cover: step 10, image 1 of 3 Polaroid I-2 Battery Replacement, Remove the bottom cover: step 10, image 2 of 3 Polaroid I-2 Battery Replacement, Remove the bottom cover: step 10, image 3 of 3
      • At this point, the bottom cover clips should be released. If not, slide an opening pick along the perimeter of the back cover to release any remaining clips.
      • Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
      • Remove the back cover.
      • During reassembly, insert the film door lever into its recess before aligning the bottom cover and pressing it into place to secure its clips.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Disconnect the film door: step 11, image 1 of 3 Polaroid I-2 Battery Replacement, Disconnect the film door: step 11, image 2 of 3 Polaroid I-2 Battery Replacement, Disconnect the film door: step 11, image 3 of 3
      • Insert the flat end of a spudger between the film door's left hinge and the frame.
      • Twist the spudger to separate the rubber hinge grommet from its peg in the frame.
      • Pull the film door towards the front of the camera to completely disconnect its left hinge.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement: step 12, image 1 of 3 Polaroid I-2 Battery Replacement: step 12, image 2 of 3 Polaroid I-2 Battery Replacement: step 12, image 3 of 3
      • Tilt the left edge of the film door up to separate the left hinge's rubber grommet.
      • Remove the film door.
      • At this point, you can remove the cloth blocker from under the print roller.
      • During reassembly, hook the left hinge on its post and push the right hinge over its post until it snaps into place.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Unfasten the back cover: step 13, image 1 of 1
      • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the back cover.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement, Unclip the back cover: step 14, image 1 of 3 Polaroid I-2 Battery Replacement, Unclip the back cover: step 14, image 2 of 3 Polaroid I-2 Battery Replacement, Unclip the back cover: step 14, image 3 of 3
      • There are two alignment pegs along the bottom edge of the back cover.
      • Insert a spudger between the frame and the alignment hole on the back cover.
      • Twist the spudger to lift the back cover off of the alignment peg.
      • Repeat for the second alignment peg.
      Ask FixBot
    3. Polaroid I-2 Battery Replacement, Disassembly information: step 15, image 1 of 3 Polaroid I-2 Battery Replacement, Disassembly information: step 15, image 2 of 3 Polaroid I-2 Battery Replacement, Disassembly information: step 15, image 3 of 3
      • There are eight large clips that secure the back cover. The next four steps show how to release them.
      • These clips are very strong and require significant force to release.
      • The procedure to release the clips is tricky and will require time and patience to perform correctly.
      Ask FixBot
    4. Polaroid I-2 Battery Replacement, Insert an opening pick: step 16, image 1 of 3 Polaroid I-2 Battery Replacement, Insert an opening pick: step 16, image 2 of 3 Polaroid I-2 Battery Replacement, Insert an opening pick: step 16, image 3 of 3
      • Releasing the clips requires getting a tool between the covered "thin" edge of the front cover and the clips themselves.
      • Angle an opening pick upward and insert it at the gap where the bottom right corner of the back cover meets the triangular tip of the front cover’s right edge.
      • Push the pick up to get it above the overhanging lip in the back cover.
      • You'll see the plastic warp a little. This is normal.
      • While pushing upward, slowly rotate the pick towards the left edge of the camera until it's under the front cover.
      • The pick can slip out easily, so this may take a few tries.
      Ask FixBot
    5. Polaroid I-2 Battery Replacement: step 17, image 1 of 3 Polaroid I-2 Battery Replacement: step 17, image 2 of 3 Polaroid I-2 Battery Replacement: step 17, image 3 of 3
      • While pushing the pick downward, slide it all the way up the right edge to release the clips.
      • Keep the pick as upright as possible while sliding to avoid hitting the clips.
      • The plastic in the lip of the back cover will warp. This is normal.
      • Leave the pick at the top corner before continuing to prevent the clips from resecuring.
      Ask FixBot
    6. Polaroid I-2 Battery Replacement: step 18, image 1 of 3 Polaroid I-2 Battery Replacement: step 18, image 2 of 3 Polaroid I-2 Battery Replacement: step 18, image 3 of 3
      • Angle a second opening pick upward and insert it at the gap where the bottom left corner of the back cover meets the triangular tip of the front cover’s left edge.
      • While pushing upward, slowly rotate the pick towards the right edge of the camera until it's under the front cover.
      Ask FixBot
    7. Polaroid I-2 Battery Replacement: step 19, image 1 of 3 Polaroid I-2 Battery Replacement: step 19, image 2 of 3 Polaroid I-2 Battery Replacement: step 19, image 3 of 3
      • While pushing the pick downward, slide it all the way up the left edge to release the remaining clips.
      Ask FixBot
    8. Polaroid I-2 Battery Replacement, Reposition the back cover: step 20, image 1 of 3 Polaroid I-2 Battery Replacement, Reposition the back cover: step 20, image 2 of 3 Polaroid I-2 Battery Replacement, Reposition the back cover: step 20, image 3 of 3
      • Don't try to pull the back cover off just yet, as it's still connected by a cable.
      • At this point, the back cover should feel loose. If any parts still feel connected, repeat the last four steps until all the clips release.
      • Pull the back cover off the camera and rotate it over the right edge to expose the flex cable.
      • During reassembly, make sure the the flex cable isn't caught between the covers before re‑engaging the clips.
      Ask FixBot
    9. Polaroid I-2 Battery Replacement, Remove the tape: step 21, image 1 of 3 Polaroid I-2 Battery Replacement, Remove the tape: step 21, image 2 of 3 Polaroid I-2 Battery Replacement, Remove the tape: step 21, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to peel off the tape covering the interconnect cable ZIF connector on the control board.
      • Set the tape aside. You'll reuse it during reassembly.
      Ask FixBot
    10. Polaroid I-2 Battery Replacement, Disconnect the control board: step 22, image 1 of 2 Polaroid I-2 Battery Replacement, Disconnect the control board: step 22, image 2 of 2
      • Use the flat end of a spudger to lift up the locking flap on the control board ZIF connector.
      Ask FixBot
    11. Polaroid I-2 Battery Replacement: step 23, image 1 of 3 Polaroid I-2 Battery Replacement: step 23, image 2 of 3 Polaroid I-2 Battery Replacement: step 23, image 3 of 3
      • Use tweezers to pull the interconnect cable out of its slot in the control board.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Unfasten the top cover: step 24, image 1 of 3 Polaroid I-2 Battery Replacement, Unfasten the top cover: step 24, image 2 of 3 Polaroid I-2 Battery Replacement, Unfasten the top cover: step 24, image 3 of 3
      • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the top cover.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement, Unclip the top cover: step 25, image 1 of 2 Polaroid I-2 Battery Replacement, Unclip the top cover: step 25, image 2 of 2
      • The next six steps demonstrate how to release the top cover's clips. These clips can re-engage easily, so you may need to repeat certain steps to release all of the clips.
      • Angle an opening pick upward and insert in the gap at the top right corner of the top cover and front cover, next to the flash.
      Ask FixBot
    3. Polaroid I-2 Battery Replacement: step 26, image 1 of 2 Polaroid I-2 Battery Replacement: step 26, image 2 of 2
      • Leave the pick in the gap before continuing to prevent the clips from re‑engaging.
      Ask FixBot
    4. Polaroid I-2 Battery Replacement: step 27, image 1 of 2 Polaroid I-2 Battery Replacement: step 27, image 2 of 2
      • Angle a second opening pick upward and insert in the gap at the top left corner of the top cover and front cover.
      Ask FixBot
    5. Polaroid I-2 Battery Replacement: step 28, image 1 of 2 Polaroid I-2 Battery Replacement: step 28, image 2 of 2
      • Leave the pick in the gap before continuing to prevent the clips from re-engaging.
      Ask FixBot
    6. Polaroid I-2 Battery Replacement: step 29, image 1 of 2 Polaroid I-2 Battery Replacement: step 29, image 2 of 2
      • Insert the flat end of a spudger between the frame and the top cover's left external clip, above the viewfinder.
      • Twist the spudger to release the clip.
      • If one of the opening picks fall out, don't worry! Continue with the guide as normal.
      Ask FixBot
    7. Polaroid I-2 Battery Replacement: step 30, image 1 of 2 Polaroid I-2 Battery Replacement: step 30, image 2 of 2
      • Insert the tip of an opening pick between the frame and the top cover's right external clip.
      • Pry up to release the clip.
      Ask FixBot
    8. Polaroid I-2 Battery Replacement, Remove the lens cap: step 31, image 1 of 1
      • Pull the lens cap off and remove it.
      Ask FixBot
    9. Polaroid I-2 Battery Replacement, Remove the top cover: step 32, image 1 of 2 Polaroid I-2 Battery Replacement, Remove the top cover: step 32, image 2 of 2
      • Lift the top cover off the camera and remove it.
      • During reassembly, push the top cover onto the frame until the clips re-engage.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Unfasten the front cover: step 33, image 1 of 2 Polaroid I-2 Battery Replacement, Unfasten the front cover: step 33, image 2 of 2
      • Use a Phillips screwdriver to remove the four screws securing the front cover:
      • Two 5.9 mm-long screws along the back edge of the front cover
      • Flip your camera over.
      • Two 3.9 mm-long screws under the front of the camera
      Ask FixBot
    2. Polaroid I-2 Battery Replacement, Unclip the front cover: step 34, image 1 of 2 Polaroid I-2 Battery Replacement, Unclip the front cover: step 34, image 2 of 2
      • The clips that secure the front cover are tricky to release. During the removal procedure, you may have to wiggle and bend the plastic to get the clips to release properly.
      • Pull the front cover away from the lens to release the clips along the front edge and slide the viewfinder out of its cutout.
      • You'll hear a "click" and the front cover will be able to move freely.
      • During reassembly, align the viewfinder cutout over the viewfinder lens before pressing the front cover into place and re-engaging the clips.
      Ask FixBot
    3. Polaroid I-2 Battery Replacement, Remove the lidar sensor bracket: step 35, image 1 of 3 Polaroid I-2 Battery Replacement, Remove the lidar sensor bracket: step 35, image 2 of 3 Polaroid I-2 Battery Replacement, Remove the lidar sensor bracket: step 35, image 3 of 3
      Buy
      • The lidar sensor bracket is secured with two alignment pegs that fit into cutouts on the bracket.
      • Use tweezers, or your fingers, to push the lidar sensor bracket toward the lidar sensor and off its alignment pegs.
      • Remove the lidar sensor bracket.
      Ask FixBot
    4. Polaroid I-2 Battery Replacement, Remove the front cover: step 36, image 1 of 2 Polaroid I-2 Battery Replacement, Remove the front cover: step 36, image 2 of 2
      • Lift the rear of the front cover while pulling the entire cover toward the front of the camera to separate it from its lip under the lens.
      • If you're having trouble, rock the cover side-to-side while pulling.
      Ask FixBot
    5. Polaroid I-2 Battery Replacement: step 37, image 1 of 3 Polaroid I-2 Battery Replacement: step 37, image 2 of 3 Polaroid I-2 Battery Replacement: step 37, image 3 of 3
      • Lift the front of the cover over the lens.
      • Slide the front cover toward the rear of the camera until the back edge clears the viewfinder.
      Ask FixBot
    6. Polaroid I-2 Battery Replacement: step 38, image 1 of 2 Polaroid I-2 Battery Replacement: step 38, image 2 of 2
      • Remove the front cover.
      • If you're disassembling further, put the lens cover back on to prevent scratching the lens.
      • At this point, the metal film door lever and spring are at risk of falling out. If they do, follow this guide to reinstall them.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Safety information: step 39, image 1 of 2 Polaroid I-2 Battery Replacement, Safety information: step 39, image 2 of 2
      • The flash's capacitor is now exposed and can deliver a potentially dangerous electric shock if you touch the main board incorrectly.
      • To minimize the risk, make sure to either discharge the capacitor properly before continuing, or wear rubber gloves for added protection.
      • If you don't use rubber gloves, don't touch exposed parts of the main board to avoid getting shocked.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Remove the tape: step 40, image 1 of 3 Polaroid I-2 Battery Replacement, Remove the tape: step 40, image 2 of 3 Polaroid I-2 Battery Replacement, Remove the tape: step 40, image 3 of 3
      • Remove the tape covering the battery connector at the top of the main board.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement, Disconnect the battery: step 41, image 1 of 3 Polaroid I-2 Battery Replacement, Disconnect the battery: step 41, image 2 of 3 Polaroid I-2 Battery Replacement, Disconnect the battery: step 41, image 3 of 3
      • The battery connector is located on the inside of the main board.
      • Insert the tip of a spudger under the head of the battery connector, where the cables meet the head itself.
      • Pry up to disconnect the battery.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Reposition the lidar sensor: step 42, image 1 of 3 Polaroid I-2 Battery Replacement, Reposition the lidar sensor: step 42, image 2 of 3 Polaroid I-2 Battery Replacement, Reposition the lidar sensor: step 42, image 3 of 3
      • Pull the lidar sensor up and out of its slot in the frame.
      • Rotate the sensor so its exposed board is facing upward and let it hang over its slot.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement, Remove the lidar sensor: step 43, image 1 of 3 Polaroid I-2 Battery Replacement, Remove the lidar sensor: step 43, image 2 of 3 Polaroid I-2 Battery Replacement, Remove the lidar sensor: step 43, image 3 of 3
      • Use the point of a spudger to "walk" the lidar sensor cable connector out of its socket until it's disconnected.
      • Remove the lidar sensor.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Unfasten the viewfinder: step 44, image 1 of 2 Polaroid I-2 Battery Replacement, Unfasten the viewfinder: step 44, image 2 of 2
      • Use a Phillips screwdriver to remove the two 5.9 mm-long screws securing the viewfinder, one near the front of the viewfinder and the other along the side.
      • The screw near the front of the viewfinder is hidden and might require a flashlight to see properly.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement, Reposition the lidar sensor cable: step 45, image 1 of 3 Polaroid I-2 Battery Replacement, Reposition the lidar sensor cable: step 45, image 2 of 3 Polaroid I-2 Battery Replacement, Reposition the lidar sensor cable: step 45, image 3 of 3
      • Push the lidar sensor cable down through its slot in the frame.
      • Reposition the lidar sensor cable so the viewfinder can move sideways without snagging it.
      • During reassembly, make sure the cable is correctly routed under the viewfinder before reinserting any screws.
      Ask FixBot
    3. Polaroid I-2 Battery Replacement, Reposition the viewfinder: step 46, image 1 of 3 Polaroid I-2 Battery Replacement, Reposition the viewfinder: step 46, image 2 of 3 Polaroid I-2 Battery Replacement, Reposition the viewfinder: step 46, image 3 of 3
      • The viewfinder cable connector is very fragile and can accidentally disconnect during this step. Take your time and follow the instructions carefully to avoid damaging the connector.
      • If your cable accidentally disconnects, don't worry! It's unlikely the cable is damaged. Follow the next two steps to understand how to reconnect it.
      • Grip both ends of the viewfinder, making sure to secure the cable connector with your fingers.
      • Pull the front of the viewfinder away from the camera and out of its recess.
      • You may need to move the viewfinder side‑to‑side to get the plastic cutouts to flex enough for the viewfinder to slide out.
      Ask FixBot
    4. Polaroid I-2 Battery Replacement: step 47, image 1 of 2 Polaroid I-2 Battery Replacement: step 47, image 2 of 2
      • Flip the viewfinder over to access its ZIF connector on the bottom of it.
      Ask FixBot
    5. Polaroid I-2 Battery Replacement, Disconnect the viewfinder: step 48, image 1 of 2 Polaroid I-2 Battery Replacement, Disconnect the viewfinder: step 48, image 2 of 2
      • Use the tip of a spudger to lift up the locking flap on the viewfinder ZIF connector.
      Ask FixBot
    6. Polaroid I-2 Battery Replacement: step 49, image 1 of 2 Polaroid I-2 Battery Replacement: step 49, image 2 of 2
      Buy
      • Use tweezers to pull the viewfinder cable out of its slot.
      Ask FixBot
    7. Polaroid I-2 Battery Replacement, Remove the viewfinder: step 50, image 1 of 1
      • Remove the viewfinder.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Disconnect the lens assembly: step 51, image 1 of 3 Polaroid I-2 Battery Replacement, Disconnect the lens assembly: step 51, image 2 of 3 Polaroid I-2 Battery Replacement, Disconnect the lens assembly: step 51, image 3 of 3
      • Use the flat end of a spudger to lift up the locking flap on the lens assembly ZIF connector.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement: step 52, image 1 of 2 Polaroid I-2 Battery Replacement: step 52, image 2 of 2
      Buy
      • Use tweezers to pull the lens assembly cable out of its slot in the main board.
      Ask FixBot
    3. Polaroid I-2 Battery Replacement, Unfasten the lens assembly: step 53, image 1 of 3 Polaroid I-2 Battery Replacement, Unfasten the lens assembly: step 53, image 2 of 3 Polaroid I-2 Battery Replacement, Unfasten the lens assembly: step 53, image 3 of 3
      • Use a Phillips screwdriver to remove the four 5.9 mm-long screws securing the lens assembly:
      • Two screws along the top of the lens
      • One screw under the lens
      • The screw under the lens is hidden and might require a flashlight to see properly.
      • One screw along the left edge of the camera, under the capacitor.
      Ask FixBot
    4. Polaroid I-2 Battery Replacement, Disassembly information: step 54, image 1 of 3 Polaroid I-2 Battery Replacement, Disassembly information: step 54, image 2 of 3 Polaroid I-2 Battery Replacement, Disassembly information: step 54, image 3 of 3
      • The lens assembly slots against a peg on the frame. Removing the assembly requires pulling it forward enough for the peg to slide out of the cutout.
      • The capacitor will brush against the battery during this procedure. Don't force the lens assembly out to avoid puncturing the battery.
      Ask FixBot
    5. Polaroid I-2 Battery Replacement, Remove the lens assembly: step 55, image 1 of 3 Polaroid I-2 Battery Replacement, Remove the lens assembly: step 55, image 2 of 3 Polaroid I-2 Battery Replacement, Remove the lens assembly: step 55, image 3 of 3
      • Pull the lens assembly toward the front of the camera until it slides out of its alignment peg.
      • Rotate the left side of the lens assembly up to separate the capacitor from its slot in the frame.
      • If you're having trouble, try gently rocking the lens assembly side-to-side to flex the plastic in the frame.
      • During reassembly, make sure the capacitor is in its slot before realigning the lens assembly on its peg.
      Ask FixBot
    6. Polaroid I-2 Battery Replacement: step 56, image 1 of 3 Polaroid I-2 Battery Replacement: step 56, image 2 of 3 Polaroid I-2 Battery Replacement: step 56, image 3 of 3
      • Pull the lens assembly out of its slot in the frame and remove it.
      Ask FixBot
    1. Polaroid I-2 Battery Replacement, Reposition the cables: step 57, image 1 of 3 Polaroid I-2 Battery Replacement, Reposition the cables: step 57, image 2 of 3 Polaroid I-2 Battery Replacement, Reposition the cables: step 57, image 3 of 3
      • The battery, lidar, and motor cables are routed under two clips in the frame.
      • Use the point of a spudger to push the cables down and out of the clips.
      Ask FixBot
    2. Polaroid I-2 Battery Replacement: step 58, image 1 of 3 Polaroid I-2 Battery Replacement: step 58, image 2 of 3 Polaroid I-2 Battery Replacement: step 58, image 3 of 3
      Buy
      • Use tweezers to pull the cables one-by-one out of their recess and let them rest on the motor.
      • During reassembly, push the cables under the clip in the frame and "scoop" them up to make all the cables fit.
      Ask FixBot
    3. Polaroid I-2 Battery Replacement, Reposition the tape: step 59, image 1 of 3 Polaroid I-2 Battery Replacement, Reposition the tape: step 59, image 2 of 3 Polaroid I-2 Battery Replacement, Reposition the tape: step 59, image 3 of 3
      • Peel up the black tape covering the battery and let it stick to the frame before continuing.
      Ask FixBot
    4. Polaroid I-2 Battery Replacement, Separate the adhesive: step 60, image 1 of 3 Polaroid I-2 Battery Replacement, Separate the adhesive: step 60, image 2 of 3 Polaroid I-2 Battery Replacement, Separate the adhesive: step 60, image 3 of 3
      • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
      • The battery is lightly adhered to a frame.
      • Insert the flat end of a spudger under the left edge of the battery.
      • Twist the spudger to separate the adhesive enough to grip the battery with your fingers.
      Ask FixBot
    5. Polaroid I-2 Battery Replacement, Remove the battery: step 61, image 1 of 3 Polaroid I-2 Battery Replacement, Remove the battery: step 61, image 2 of 3 Polaroid I-2 Battery Replacement, Remove the battery: step 61, image 3 of 3
      • Grip the end of the battery and lift up to separate the remaining adhesive.
      • Remove the battery.
      Ask FixBot
    6. Polaroid I-2 Battery Replacement, Transfer the adhesive: step 62, image 1 of 3 Polaroid I-2 Battery Replacement, Transfer the adhesive: step 62, image 2 of 3 Polaroid I-2 Battery Replacement, Transfer the adhesive: step 62, image 3 of 3
      • If your battery comes with pre-installed adhesive pad, skip this step.
      • Use your fingers or blunt-nose tweezers to peel off the adhesive pad from the bottom of the battery.
      • During reassembly, transfer the old adhesive pad to your new battery.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
Alex Diaz-Kokaisl
248,610 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 125
All Time: 6,247
