Up to 20% off select tools
Polaroid Cube Video Quality Switch Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
96
All Time:
1,592
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 35 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the video quality switch on your Polaroid Cube. Make sure the device is completely powered off before disassembly, and that you have all of the required tools.
    1. Polaroid Cube Video Quality Switch Replacement, Battery: step 1, image 1 of 1
      • Remove the SD card cover by twisting it using a Plastic Opening Tool
      Ask FixBot
    2. Polaroid Cube Video Quality Switch Replacement: step 2, image 1 of 1
      • Use the Plastic Opening tool to pry off and remove the front cover.
      Ask FixBot
    3. Polaroid Cube Video Quality Switch Replacement: step 3, image 1 of 1
      • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
      Ask FixBot
    4. Polaroid Cube Video Quality Switch Replacement: step 4, image 1 of 2 Polaroid Cube Video Quality Switch Replacement: step 4, image 2 of 2
      • Use the Plastic Opening Tool to pry open the shell of the camera.
      • There are four latches, one at each corner, that you will need to detach.
      Ask FixBot
    5. Polaroid Cube Video Quality Switch Replacement: step 5, image 1 of 1
      • Remove shell from top and bottom of camera.
      Ask FixBot
    6. Polaroid Cube Video Quality Switch Replacement: step 6, image 1 of 1
      • Remove the rubber seal wrapped around the camera.
      Ask FixBot
    7. Polaroid Cube Video Quality Switch Replacement: step 7, image 1 of 2 Polaroid Cube Video Quality Switch Replacement: step 7, image 2 of 2
      • Remove the tape wrapped around the battery.
      Ask FixBot
    8. Polaroid Cube Video Quality Switch Replacement: step 8, image 1 of 3 Polaroid Cube Video Quality Switch Replacement: step 8, image 2 of 3 Polaroid Cube Video Quality Switch Replacement: step 8, image 3 of 3
      • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
      Ask FixBot
    9. Polaroid Cube Video Quality Switch Replacement: step 9, image 1 of 2 Polaroid Cube Video Quality Switch Replacement: step 9, image 2 of 2
      • Use the plastic opening tool to remove the circuit board that the battery is connected to.
      Ask FixBot
    10. Polaroid Cube Video Quality Switch Replacement: step 10, image 1 of 1
      • Gently remove the battery pin connector from the circuit board.
      Ask FixBot
    1. Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: step 11, image 1 of 2 Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: step 11, image 2 of 2
      • Using a J00 head screwdriver, unscrew the 3.46mm screw that connects the top circuit board to the video quality switch board.
      Ask FixBot
    2. Polaroid Cube Video Quality Switch Replacement: step 12, image 1 of 1
      • Remove the circuit board.
      Ask FixBot
    3. Polaroid Cube Video Quality Switch Replacement: step 13, image 1 of 2 Polaroid Cube Video Quality Switch Replacement: step 13, image 2 of 2
      • Using a J00 head screwdriver, unscrew the two 3.46mm screws connecting the video quality switch to the case.
      • Remove and replace the broken video quality switch.
      Ask FixBot
4 other people completed this guide.
Author
with
Grant Baldwin
685 Reputation
2 Guides authored
IUPUI, Team 3-2, Harley Fall 2016 Member of IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 96
All Time: 1,592
