Polaroid Cube Battery Replacement
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
130
All Time:
11,182
Comments: 13
13 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will walk you through the steps of replacing the battery on your Polaroid Cube. Make sure the device is completely powered off before disassembly, and that you have all of the required tools.
Tools
    1. Polaroid Cube Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the SD card cover by twisting it using a Plastic Opening Tool
      Ask FixBot
    2. Polaroid Cube Battery Replacement: step 2, image 1 of 1
      • Use the Plastic Opening tool to pry off and remove the front cover.
      Ask FixBot
    3. Polaroid Cube Battery Replacement: step 3, image 1 of 1
      • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
      Ask FixBot
    4. Polaroid Cube Battery Replacement: step 4, image 1 of 2 Polaroid Cube Battery Replacement: step 4, image 2 of 2
      • Use the Plastic Opening Tool to pry open the shell of the camera.
      • There are four latches, one at each corner, that you will need to detach.
      Ask FixBot
    5. Polaroid Cube Battery Replacement: step 5, image 1 of 1
      • Remove shell from top and bottom of camera.
      Ask FixBot
    6. Polaroid Cube Battery Replacement: step 6, image 1 of 1
      • Remove the rubber seal wrapped around the camera.
      Ask FixBot
    7. Polaroid Cube Battery Replacement: step 7, image 1 of 2 Polaroid Cube Battery Replacement: step 7, image 2 of 2
      • Remove the tape wrapped around the battery.
      Ask FixBot
    8. Polaroid Cube Battery Replacement: step 8, image 1 of 3 Polaroid Cube Battery Replacement: step 8, image 2 of 3 Polaroid Cube Battery Replacement: step 8, image 3 of 3
      • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
      Ask FixBot
    9. Polaroid Cube Battery Replacement: step 9, image 1 of 2 Polaroid Cube Battery Replacement: step 9, image 2 of 2
      • Use the plastic opening tool to remove the circuit board that the battery is connected to.
      Ask FixBot
    10. Polaroid Cube Battery Replacement: step 10, image 1 of 1
      • Gently remove the battery pin connector from the circuit board.
      Ask FixBot
10 other people completed this guide.
heath lamkin
372 Reputation
1 Guide authored
IUPUI, Team 3-2, Harley Fall 2016 Member of IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Members
36 Guides authored
13 Guide Comments
Any idea where to find the replacement batteries?
hooverhogg - Reply Share
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
seyhangul - Reply Share
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
David F O'Connor - Reply Share
Was anyone able to to find the replacement batteries for the Cube?
yzorger - Reply Share
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Timothy Davenport - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 130
All Time: 11,182
