Polaroid Automatic 100 Spread Roll Replacement
    1. Polaroid Automatic 100 Spread Roll Replacement, Spread Roll: step 1, image 1 of 2 Polaroid Automatic 100 Spread Roll Replacement, Spread Roll: step 1, image 2 of 2
      • Push the lever on the bottom of the camera towards the left.
      • Open the rear door of the camera.
      Ask FixBot
    2. Polaroid Automatic 100 Spread Roll Replacement: step 2, image 1 of 3 Polaroid Automatic 100 Spread Roll Replacement: step 2, image 2 of 3 Polaroid Automatic 100 Spread Roll Replacement: step 2, image 3 of 3
      • Unlatch the red clip on the side.
      • Lift the rollers up.
      • Position the camera with the back cover closest to you.
      Ask FixBot
    3. Polaroid Automatic 100 Spread Roll Replacement: step 3, image 1 of 3 Polaroid Automatic 100 Spread Roll Replacement: step 3, image 2 of 3 Polaroid Automatic 100 Spread Roll Replacement: step 3, image 3 of 3
      • Remove the rear roll by using the plastic opening tool to take it off the metal frame.
      • Then remove the front roll by pushing away from you with the plastic opening tool.
      Ask FixBot
    4. Polaroid Automatic 100 Spread Roll Replacement: step 4, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Unscrew the three 2.5 mm screws (attached to the metal plate) with a 3.0 flathead screwdriver. Then take off the metal plate.
      Ask FixBot
    5. Polaroid Automatic 100 Spread Roll Replacement: step 5, image 1 of 1
      • Pull the support rod out.
      Ask FixBot
Katie Miller
680 Reputation
5 Guides authored
Cal Poly, Team 4-3, Maness Spring 2015 Member of Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Members
59 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 1,121
