Up to 20% off select tools
Polaroid Automatic 100 Bottom Frame Spring Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
104
All Time:
1,898
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
The spring is located within a slender metal mount that is screwed into the front underside of the Polaroid. It is below the camera lens and can be seen through the mount it is within.
    1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: step 1, image 1 of 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: step 1, image 2 of 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: step 1, image 3 of 3
      • Fully extend the bellows to prevent collapse using the #1 tab.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      Ask FixBot
    2. Polaroid Automatic 100 Bottom Frame Spring Replacement: step 2, image 1 of 1
      • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
      Ask FixBot
    3. Polaroid Automatic 100 Bottom Frame Spring Replacement: step 3, image 1 of 1
      • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
      Ask FixBot
    4. Polaroid Automatic 100 Bottom Frame Spring Replacement: step 4, image 1 of 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: step 4, image 2 of 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: step 4, image 3 of 3
      • Remove the spring from the shutter mount.
      • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
      • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
      Ask FixBot
2 other people completed this guide.
Author
with
Katie Miller
680 Reputation
5 Guides authored
Cal Poly, Team 4-3, Maness Spring 2015 Member of Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Members
60 Guides authored
2 Guide Comments
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Reply Share
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 104
All Time: 1,898
