Polaroid Automatic 100 Bellows Replacement
    1. Polaroid Automatic 100 Bellows Replacement, Bellows: step 1, image 1 of 3 Polaroid Automatic 100 Bellows Replacement, Bellows: step 1, image 2 of 3 Polaroid Automatic 100 Bellows Replacement, Bellows: step 1, image 3 of 3
      • Fully extend the bellows by lifting the #1 lever.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      Ask FixBot
    2. Polaroid Automatic 100 Bellows Replacement: step 2, image 1 of 1
      • Peel the two battery cable tabs off of the bellows.
      Ask FixBot
    3. Polaroid Automatic 100 Bellows Replacement: step 3, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
      • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
      • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
      Ask FixBot
    4. Polaroid Automatic 100 Bellows Replacement: step 4, image 1 of 2 Polaroid Automatic 100 Bellows Replacement: step 4, image 2 of 2
      • Open the back cover by pushing the lever on the bottom towards the left.
      Ask FixBot
    5. Polaroid Automatic 100 Bellows Replacement: step 5, image 1 of 1
      • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
      • To make the screws easily accessible, close the bellows by pushing on the metal frame.
      • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
      Ask FixBot
    6. Polaroid Automatic 100 Bellows Replacement: step 6, image 1 of 1
      • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
      Ask FixBot
    7. Polaroid Automatic 100 Bellows Replacement: step 7, image 1 of 2 Polaroid Automatic 100 Bellows Replacement: step 7, image 2 of 2
      • Pull the bellow tabs back with long needle nose pliers.
      • Remove the bellows.
      Ask FixBot
2 other people completed this guide.
Katie Miller
680 Reputation
5 Guides authored
Cal Poly, Team 4-3, Maness Spring 2015 Member of Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Members
59 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 37
All Time: 2,778
