Introduction
The most common problem to replace your motherboard would be if your battery charging port is damaged. This guide will assist you step-by-step on how to take apart and replace it.
Begin by having the side with volume and power button face up towards you.
Insert a plastic opening tool between the display and the back cover.
Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
Take off yellow tapes that are surrounding the motherboard.
Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
