Up to 20% off select tools
Polaroid A10 Front/Back Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
85
All Time:
812
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This Polaroid A10 Front/Back Camera Replacement guide might be needed if either your front, back, or both camera lenses are damaged, shattered, and/or scratched. If only one of your camera lenses are damaged, you will be replacing both front and back cameras because they are both contained in a single component. To acquire further information regarding the Polaroid A10 front/back camera replacement, follow this efficient guide to escort you through the replacement procedures.
    1. Polaroid A10 Front/Back Camera Replacement, Back Cover: step 1, image 1 of 3 Polaroid A10 Front/Back Camera Replacement, Back Cover: step 1, image 2 of 3 Polaroid A10 Front/Back Camera Replacement, Back Cover: step 1, image 3 of 3
      • Begin by having the side with volume and power button face up towards you.
      • Insert a plastic opening tool between the display and the back cover.
      • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
      • It is easier to remove the back cover, if the display screen is faced down.
      • The tabs must be released from all four sides before removing the back cover.
      Ask FixBot
    1. Polaroid A10 Front/Back Camera Replacement, Battery: step 2, image 1 of 3 Polaroid A10 Front/Back Camera Replacement, Battery: step 2, image 2 of 3 Polaroid A10 Front/Back Camera Replacement, Battery: step 2, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
      • It is better to use a plastic card if you have one.
      • Gently lift up the battery as you continue to separate the glue from the battery.
      • Lift up just enough to see where the glue is, so that you don't bend the battery.
      • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
      Ask FixBot
    2. Polaroid A10 Front/Back Camera Replacement: step 3, image 1 of 3 Polaroid A10 Front/Back Camera Replacement: step 3, image 2 of 3 Polaroid A10 Front/Back Camera Replacement: step 3, image 3 of 3
      Ask FixBot
    3. Polaroid A10 Front/Back Camera Replacement: step 4, image 1 of 1
      • Gently lift the battery up and out of the device.
      Ask FixBot
    1. Polaroid A10 Front/Back Camera Replacement, Front/Back Camera: step 5, image 1 of 1
      • The camera head is located on the upper middle section of the device, close to the battery.
      Ask FixBot
    2. Polaroid A10 Front/Back Camera Replacement: step 6, image 1 of 2 Polaroid A10 Front/Back Camera Replacement: step 6, image 2 of 2
      • Start by locating the two left and right screws which hold the camera head in place.
      • Using the Phillip's 000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
      Ask FixBot
    3. Polaroid A10 Front/Back Camera Replacement: step 7, image 1 of 3 Polaroid A10 Front/Back Camera Replacement: step 7, image 2 of 3 Polaroid A10 Front/Back Camera Replacement: step 7, image 3 of 3
      • Locate the camera ribbon cable that is connected to the motherboard.
      • With a spudger, remove the camera ribbon cable base from the motherboard connector.
      • With one finger, delicately remove the camera ribbon cable by sliding down.
      Ask FixBot
Author
with
Shilpa Verma
353 Reputation
3 Guides authored
UW Tacoma, Team 3-3, Rose Winter 2015 Member of UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 85
All Time: 812
