Polarizer Replacement for Tri-LCD Projectors
Views: 12K
View statistics:
Past 24 Hours:
22
Past 7 Days:
131
Past 30 Days:
507
All Time:
11,781
Comments: 10
2 comments on steps, 8 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your projector is projecting an image with a green tint, this may indicate a burned green polarizing filter. In this guide, I will show how to replace it, as well as share a few other tips on solving image issues. I will be working on a Powerlite 93+ in this guide, but most Epson Tri-LCD projectors are built very similarly, and the concepts in this guide can be carried over to any Tri-LCD projector.
    1. Polarizer Replacement for Tri-LCD Projectors, Polarizers: step 1, image 1 of 2 Polarizer Replacement for Tri-LCD Projectors, Polarizers: step 1, image 2 of 2
      • First of all, there are five screw sizes you'll encounter in this guide. I'll refer to them as size 1-5 throughout this guide.
      • Far Left (size 1): These screws secure the mainboard. There is also one helping to secure the I/O plate.
      • 2nd from left (size 2): This screw secures a ground wire to the I/O plate.
      • 3rd from left (size 3): These screws are used exclusively on the I/O plate.
      • 4th from left (size 4): These screws hold the projector's outer case together.
      • 2nd picture (size 5): Two of these screws secure the yoke assembly.
      Ask FixBot
    2. Polarizer Replacement for Tri-LCD Projectors: step 2, image 1 of 1
      • Start by removing these two screws (size 4) underneath the lamp cover.
      • Removing the lamp is not necessary for this repair, but may make the job easier.
      Ask FixBot
    3. Polarizer Replacement for Tri-LCD Projectors: step 3, image 1 of 2 Polarizer Replacement for Tri-LCD Projectors: step 3, image 2 of 2
      • Remove these 5 screws (size 3) followed by the panel they secure.
      Ask FixBot
    4. Polarizer Replacement for Tri-LCD Projectors: step 4, image 1 of 1
      • Remove these 8 screws (size 4) which secure the top cover
      Ask FixBot
    5. Polarizer Replacement for Tri-LCD Projectors: step 5, image 1 of 1
      • Open the air filter cover, otherwise it will prevent the top cover from being opened
      Ask FixBot
    6. Polarizer Replacement for Tri-LCD Projectors, Remove the Main Cover: step 6, image 1 of 1
      • Place the projector right-side up and lift off the cover. Be sure to remove this ribbon cable.
      Ask FixBot
    7. Polarizer Replacement for Tri-LCD Projectors: step 7, image 1 of 1
      • Remove all 4 size 1 screws in RED.
      • Depending on your specific model of projector, you may also need to remove the black trim piece underneath the screw in the bottom right corner.
      • Do not remove the screw inside the BLUE circle. Doing so will cause a metal brace to fall into the projector which is difficult to reinstall.
      Ask FixBot
    8. Polarizer Replacement for Tri-LCD Projectors: step 8, image 1 of 1
      • Unplug all of these connectors.
      • Note that one on the top left corner is on the bottom of the board
      • Although the metal shield is removed in this picture, you do not need to remove it
      • Removing these connectors will allow you to flip the board up and out of the way. If you want to remove it completely, unplug all the connectors
      • Don't worry much about not being able to remember where each cable goes, most of them use different connectors to make it impossible to mess up
      Ask FixBot
    9. Polarizer Replacement for Tri-LCD Projectors: step 9, image 1 of 1
      • Remove this screw (size 3).
      Ask FixBot
    10. Polarizer Replacement for Tri-LCD Projectors: step 10, image 1 of 1
      • Remove the left screw (size 1)
      • Remove the right screw (size 2)
      Ask FixBot
    11. Polarizer Replacement for Tri-LCD Projectors, Remove the Mainboard: step 11, image 1 of 1
      • Carefully flip the mainboard up to the right.
      • The board WILL catch on the bottom left corner, so be careful.
      • Side note: another common problem is having one of the mirrors fall out of place due to heat. It may be a good idea at this step to remove the cover of the mirror housing and check for this problem. If one of them has fallen off, use two-part epoxy to put it back in place, making sure to keep it pressed firmly and evenly against its seat.
      Ask FixBot
    12. Polarizer Replacement for Tri-LCD Projectors, Remove the Polarizer: step 12, image 1 of 1
      • This is the green polarizer
      • Remove the screw and pull it out
      Ask FixBot
    13. Polarizer Replacement for Tri-LCD Projectors: step 13, image 1 of 1
      • This is a burned polarizer.
      • If yours looks like this, you've found your problem.
      Ask FixBot
    14. Polarizer Replacement for Tri-LCD Projectors: step 14, image 1 of 1
      • This is what a good polarizer should look like.
      • You'll need to source a new one, which can be tricky. Lots of Epson projectors use the same polarizer though, so you may be able to pull one from a different projector.
      Ask FixBot
    15. Polarizer Replacement for Tri-LCD Projectors: step 15, image 1 of 1
      • Once you have a new polarizer, install it and the mainboard in order to test the projector. There is a kill switch for the lamp door you will need to hold down in order to power on the projector while it is disassembled.
      • If the level of green looks good, you are finished and can proceed with reassembly
      • If the level of green looks off, proceed to step 16
      Ask FixBot
    16. Polarizer Replacement for Tri-LCD Projectors: step 16, image 1 of 1
      • As you can see, the screw doubles as an adjustment point, which you may have to adjust to get a good green level.
      • Cut through the glue and slide the polarizer left or right until the projector's color looks good. This can be a bit tedious because you need to reinstall the mainboard to test it between each adjustment.
      • Sliding to the left will increase the amount of green let through.
      • Sliding to the right will decrease it.
      • Once you get it adjusted how you want, you're done! Just reassemble the projector and you're good to go.
      Ask FixBot
6 other people completed this guide.
Timothy Fryer
701 Reputation
2 Guides authored
8 Guide Comments
Where did you order the polarizers from?
fl sf - Reply Share
hola tengo un epson 395W me hace una mancha roja por un lado y el lado contrario una azul que cubre el lateral y la parte superior los puedo reemplazar por otros de misma serie powerlite sin importar que no tengan la misma nomenclatura ejemplo H395R el mio y este de la imagen aqui de ejemplo es H372R unicamente tienen que ser de el tamaño y color igual ? Gracias
Ernesto Bucio - Reply Share
Your issue sounds more like a mirror that has fallen off. I'd recommend disassembling through step 11, removing the cover of the mirror housing (large black "U" shaped piece) and checking if there is a loose mirror. If there is, two part epoxy can be used to glue it back in place. If you do need a new polarizer, they are compatible across most Epson models, but I don't know specifically which ones. If it looks visually similar, it should fit.
Su problema suena más como un espejo que se ha caído. Recomendaría desarmar hasta el paso 11, quitar la cubierta de la carcasa del espejo (pieza grande negra en forma de "U") y verificar si hay un espejo suelto. Si es así, se puede utilizar epoxi de dos componentes para volver a pegarlo en su lugar. Si necesita un polarizador nuevo, son compatibles con la mayoría de los modelos Epson, pero no sé específicamente cuáles. Si se ve visualmente similar, debería encajar.
Timothy Fryer - Reply Share
I have a Epson 535W that I bought used and I have a thin red line on the right hand edge of the projection. I have tried everything in the settings to get rid of it, after reading over your steps about the polarizer removal , I think it might be that one of the mirrors might have moved. Would the line be cause by the mirror or a defective polarizer? Thanks for this article it is great.
TBS99 - Reply Share
In my experience, a defective polarizing filter will discolor the entire image, so probably no issue there. Here's a couple of things to check; first, is there a corresponding greenish line on the left side of the screen? And looking closely at the screen, does the R,G, or B element of each pixel not quite line up? If so, one of your LCDs is misaligned. You could try reseating whichever LCD corresponds the the misaligned color, but I haven't had much luck fixing this problem so I don't have much advice to offer here. I'll re-add a section to this guide to aid in disassembling this section. Second, pick the projector up and rotate it around a bit while it's running. Does the red area change at all? If so, your issue is definitely a loose mirror, which should be a much easier fix. Hope this helps!
Past 24 Hours: 22
Past 7 Days: 131
Past 30 Days: 507
All Time: 11,781
