Polar Wind 8" High Velocity Fan Blades Replacement
    1. Polar Wind 8" High Velocity Fan Blades Replacement, Fan Blades: step 1, image 1 of 2 Polar Wind 8" High Velocity Fan Blades Replacement, Fan Blades: step 1, image 2 of 2
      • Use a Y000 tri-point screwdriver to remove four screws from the backside of your the fan, turning counterclockwise.
      • Caution: Ensure your Polar Wind fan is shut OFF and unplugged before proceeding to avoid injury.
      Ask FixBot
    2. Polar Wind 8" High Velocity Fan Blades Replacement: step 2, image 1 of 2 Polar Wind 8" High Velocity Fan Blades Replacement: step 2, image 2 of 2
      • Separate the cover from the back with your hands and set aside.
      Ask FixBot
    3. Polar Wind 8" High Velocity Fan Blades Replacement: step 3, image 1 of 2 Polar Wind 8" High Velocity Fan Blades Replacement: step 3, image 2 of 2
      • Use a Y000 tri-point screwdriver to remove the two screws from under the fan blades, turning counterclockwise.
      Ask FixBot
    4. Polar Wind 8" High Velocity Fan Blades Replacement: step 4, image 1 of 3 Polar Wind 8" High Velocity Fan Blades Replacement: step 4, image 2 of 3 Polar Wind 8" High Velocity Fan Blades Replacement: step 4, image 3 of 3
      • Carefully remove the fan blades by holding the base and lifting it up out of the motor.
      • There are two bands loosely attached to the bottom of the rod. Do not misplace the bands.
      Ask FixBot
    5. Polar Wind 8" High Velocity Fan Blades Replacement: step 5, image 1 of 3 Polar Wind 8" High Velocity Fan Blades Replacement: step 5, image 2 of 3 Polar Wind 8" High Velocity Fan Blades Replacement: step 5, image 3 of 3
      • Firmly grasp the base of the blades, pushing it down and turning clockwise to slide down to the base of the rod.
      • Use a pair of pliers to remove the center disk by pinching the rim and pulling upwards.
      • Once it is loosened, squeeze the bottom of the disk and the tip of the rod between your pliers to more easily remove the disk.
      • The disk may be difficult to remove. Using lube may help slide it off more easily, but it is not required.
      Ask FixBot
    6. Polar Wind 8" High Velocity Fan Blades Replacement: step 6, image 1 of 3 Polar Wind 8" High Velocity Fan Blades Replacement: step 6, image 2 of 3 Polar Wind 8" High Velocity Fan Blades Replacement: step 6, image 3 of 3
      • Once removed, set the center disk aside.
      • Firmly grasp the base of the fan blades, pulling upwards and turning counterclockwise.
      • Set old blades aside to be recycled later, and replace with the new blades.
      • Once you begin to reassemble your device, push the disk back onto the rod using your hand, then use the pliers to pull it down the rest of the way, until there is at least 1/4" between the disk and tip of the rod.
      Ask FixBot
1 Guide Comment
How (where) can I purchase a "center disc" from? I wish I seen this info before I disassembled it incorrectly. **(blade cracked off, so I cut broken area off by doing so bent center disc. SO I need to find where purchase a replacement blade & center disc. Thanks.
Djames ZW - Reply Share
Past 24 Hours: 6
Past 7 Days: 13
Past 30 Days: 58
All Time: 2,515
