Polar V800 Charging Port Cover Replacement
    1. Polar V800 Charging Port Cover Replacement, Watch Band: step 1, image 1 of 3 Polar V800 Charging Port Cover Replacement, Watch Band: step 1, image 2 of 3 Polar V800 Charging Port Cover Replacement, Watch Band: step 1, image 3 of 3
      • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
      • Completely pull out the pins.
      • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
      • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
      Ask FixBot
    2. Polar V800 Charging Port Cover Replacement: step 2, image 1 of 3 Polar V800 Charging Port Cover Replacement: step 2, image 2 of 3 Polar V800 Charging Port Cover Replacement: step 2, image 3 of 3
      • To remove the watch band, pull each end of the watch band away from the watch frame.
      Ask FixBot
    1. Polar V800 Charging Port Cover Replacement, Charging Port Cover: step 3, image 1 of 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: step 3, image 2 of 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: step 3, image 3 of 3
      • Take off the charging port cover.
      Ask FixBot
Nick B.
392 Reputation
1 Guide authored
Cal Poly, Team S17-G6, Livingston Spring 2018 Member of Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Members
60 Guides authored
1 Guide Comment
where does not procure the battery port cover ?
Chenthill P - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 40
All Time: 3,446
