Polar M400 Watch micro-USB connector Replacement
    1. Polar M400 Watch micro-USB connector Replacement, Wrist Strap: step 1, image 1 of 1
      • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
      Ask FixBot
    2. Polar M400 Watch micro-USB connector Replacement: step 2, image 1 of 2 Polar M400 Watch micro-USB connector Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Apply an upward pressure to the holes until the locking pins release.
      • Use precision tweezers to remove the pins that connect the face with the strap.
      Ask FixBot
    3. Polar M400 Watch micro-USB connector Replacement: step 3, image 1 of 1
      • Once the pins are released, the old wrist strap should snap off.
      • Simply lock the new wrist strap into place.
      Ask FixBot
    1. Polar M400 Watch micro-USB connector Replacement, Battery: step 4, image 1 of 1
      • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
      Ask FixBot
    2. Polar M400 Watch micro-USB connector Replacement: step 5, image 1 of 2 Polar M400 Watch micro-USB connector Replacement: step 5, image 2 of 2
      • Gently remove the backing from the watch.
      Ask FixBot
    3. Polar M400 Watch micro-USB connector Replacement: step 6, image 1 of 2 Polar M400 Watch micro-USB connector Replacement: step 6, image 2 of 2
      Buy
      • Use tweezers to gently pry the golden sensor away from the battery.
      • Remove battery using the plastic opening tools.
      Ask FixBot
    1. Polar M400 Watch micro-USB connector Replacement, Screen: step 7, image 1 of 2 Polar M400 Watch micro-USB connector Replacement, Screen: step 7, image 2 of 2
      • Detach the screen from the screen protector using a PH000 screwdriver.
      Ask FixBot
    2. Polar M400 Watch micro-USB connector Replacement: step 8, image 1 of 2 Polar M400 Watch micro-USB connector Replacement: step 8, image 2 of 2
      • Attach a new screen to the screen protector.
      • Make sure that the charging port remains accessible, as it can easily become detached during the replacement.
      Ask FixBot
    1. Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: step 9, image 1 of 3 Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: step 9, image 2 of 3 Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: step 9, image 3 of 3
      • Follow the screen replacement tutorial to dismantle the watch.
      • Carefully lift the screen from the board.
      • Disconnect the USB's flex PCB from the main board. Save the red rubber seal of the USB connector for later.
      Ask FixBot
      • Use a tool like a helping hand to hold the USB connector part.
      • Using a heat gun, blow hot air underneath the PCB.
      • Once the solder is melting give the connector a good tap in order to make the PCB fall loose.
      Ask FixBot
    2. Polar M400 Watch micro-USB connector Replacement, Soldering a new USB connector: step 11, image 1 of 2 Polar M400 Watch micro-USB connector Replacement, Soldering a new USB connector: step 11, image 2 of 2
      • Place the new USB connector on a flat surface with its pins pointing upwards.
      • Place the PCB on top on the pins, the exposed copper traces on the flex PCB facing the flat surface.
      • Using an iron, solder the PCB by heating all the pads at the same time (as much as possible) and apply pressure so that the pins of the USB connector come through.
      Ask FixBot
    3. Polar M400 Watch micro-USB connector Replacement, Sealing the USB connector: step 12, image 1 of 2 Polar M400 Watch micro-USB connector Replacement, Sealing the USB connector: step 12, image 2 of 2
      • Connect the flex PCB back to the main board.
      • Reassemble the watch stopping before screwing the lid back.
      • Add hot glue to the base of the USB connector filling the watch case's cavity. Be careful not to put hot glue inside the connector.
      • While the glue is still hot, put the red rubber seal back on top.
      • Screw the lid back.
      Ask FixBot
6 other people completed this guide.
Benjamin Freeman
289 Reputation
1 Guide authored
11 Guide Comments
Sehr gute Beschreibung,
aber ich finde keine USB-Buchse für die M400 zu kaufen
Wo gibt's die Teile?
martinmartinez644 - Reply Share
Danke schön. Für den Konnektor allein habe ich auf Aliexpress gekauft : https://www.aliexpress.com/item/32960430...
Benjamin Freeman - Reply Share
From where do I order usb connector?
Pankaj Singh - Reply Share
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 154
All Time: 23,300
