Polar M400 Watch Battery Replacement
Views: 37K
View statistics:
Past 24 Hours:
10
Past 7 Days:
41
Past 30 Days:
229
All Time:
37,005
Comments: 33
8 comments on steps, 25 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will teach someone how to take out the battery in the Polar M400 and replace it with a working one. A damaged battery could be due to lack of charge or submersion in water more than 30 meters. It could also be due to battery age and various malfunctions. Over time, excessive and wear can lead to battery damage. The Polar M400 has an internal, rechargeable battery. You can charge the battery over 300 times or two years before a notable decrease in its capacity. The number of charge cycles also varies depending on use and operating conditions. Once the battery is replaced, follow local waste disposal regulations and do not dispose of this product as unsorted municipal waste.
Parts
Tools
    1. Polar M400 Watch Battery Replacement, Wrist Strap: step 1, image 1 of 1
      • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
      Ask FixBot
    2. Polar M400 Watch Battery Replacement: step 2, image 1 of 2 Polar M400 Watch Battery Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Apply an upward pressure to the holes until the locking pins release.
      • Use precision tweezers to remove the pins that connect the face with the strap.
      Ask FixBot
    3. Polar M400 Watch Battery Replacement: step 3, image 1 of 1
      • Once the pins are released, the old wrist strap should snap off.
      • Simply lock the new wrist strap into place.
      Ask FixBot
    1. Polar M400 Watch Battery Replacement, Battery: step 4, image 1 of 1
      • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
      Ask FixBot
    2. Polar M400 Watch Battery Replacement: step 5, image 1 of 2 Polar M400 Watch Battery Replacement: step 5, image 2 of 2
      • Gently remove the backing from the watch.
      Ask FixBot
    3. Polar M400 Watch Battery Replacement: step 6, image 1 of 2 Polar M400 Watch Battery Replacement: step 6, image 2 of 2
      Buy
      • Use tweezers to gently pry the golden sensor away from the battery.
      • Remove battery using the plastic opening tools.
      Ask FixBot
16 other people completed this guide.
Nicholas Sanders
543 Reputation
2 Guides authored
25 Guide Comments
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Reply Share
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman - Reply Share
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Reply Share
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Reply Share
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Reply Share
Past 24 Hours: 10
Past 7 Days: 41
Past 30 Days: 229
All Time: 37,005
