Up to 20% off select tools
Pokewalker Button Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
100
All Time:
1,605
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
How to Replace a Cracked or Broken Button on a Pokewalker
    1. Pokewalker Button Replacement, Battery: step 1, image 1 of 1
      • Locate the Screw on the Back of the Pokewalker.
      Ask FixBot
    2. Pokewalker Button Replacement: step 2, image 1 of 1
      • Remove the Screw with a Phillips #0 Screwdriver
      • The screw is attached to the rear case with washers. don't worry about losing it.
      Ask FixBot
    3. Pokewalker Button Replacement: step 3, image 1 of 1
      • Remove the Rear Cover from the Device
      Ask FixBot
    4. Pokewalker Button Replacement: step 4, image 1 of 1
      • Use the flat end of a Spudger to Remove the Battery
      Ask FixBot
      • Locate the 4 Screws Around the Device
      Ask FixBot
      • Remove all 4 screws with a Y0 Triwing Screwdriver
      Ask FixBot
      • Separate the 2 halves of the Device
      • Do not Separate Completely as the Display is Still Connected by a Ribbon Cable
      Ask FixBot
    1. Tool used on this step:
      Buy
      • Use a Spudger to Flip the Latch holding the ribbon cable in place and use Tweezers to Pull it out
      • Do not use Excessive force when reinserting the cable, because ribbon cables are fragile
      Ask FixBot
      • Remove the Rubber-button thingy from the upper case
      • I have no idea what that thing is, edit this guide if you do.
      Ask FixBot
      • Remove the 3 Plastic Buttons from the Case
      • It helps that the buttons only go in one way, makes it easier to reassemble
      Ask FixBot
Author
with
Winni Stuart
477 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 100
All Time: 1,605
