Poin2 Chromebook 11 Charging Port Replacement
  1. Poin2 Chromebook 11 Charging Port Replacement, Battery: step 1, image 1 of 2 Poin2 Chromebook 11 Charging Port Replacement, Battery: step 1, image 2 of 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Charging Port Replacement: step 2, image 1 of 3 Poin2 Chromebook 11 Charging Port Replacement: step 2, image 2 of 3 Poin2 Chromebook 11 Charging Port Replacement: step 2, image 3 of 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Charging Port Replacement: step 3, image 1 of 3 Poin2 Chromebook 11 Charging Port Replacement: step 3, image 2 of 3 Poin2 Chromebook 11 Charging Port Replacement: step 3, image 3 of 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Charging Port Replacement: step 4, image 1 of 2 Poin2 Chromebook 11 Charging Port Replacement: step 4, image 2 of 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Charging Port Replacement: step 5, image 1 of 1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Charging Port Replacement, Charging Port: step 6, image 1 of 2 Poin2 Chromebook 11 Charging Port Replacement, Charging Port: step 6, image 2 of 2
    • The changing port is located on the upper-right corner of the computer.
    • Disconnect the charging port from the motherboard using a spudger to push the 4-wire connector out from the port.
  7. Poin2 Chromebook 11 Charging Port Replacement: step 7, image 1 of 2 Poin2 Chromebook 11 Charging Port Replacement: step 7, image 2 of 2
    • Remove silver tape covering hinge.
  8. Poin2 Chromebook 11 Charging Port Replacement: step 8, image 1 of 2 Poin2 Chromebook 11 Charging Port Replacement: step 8, image 2 of 2
    • The metal hinge at the top right corner must be lifted to access the charging port.
    • Use a Phillips #0 screwdriver and remove the two 7mm screws from the hinge.
  9. Poin2 Chromebook 11 Charging Port Replacement: step 9, image 1 of 1
    • Pry the metal hinge up, until it sits perpendicular to the motherboard.
    • The metal hinge is a tight fit and requires careful strength when lifting.
  10. Poin2 Chromebook 11 Charging Port Replacement: step 10, image 1 of 2 Poin2 Chromebook 11 Charging Port Replacement: step 10, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to gently pull the charging port out of the frame.
4 other people completed this guide.
Jesse Johnson
357 Reputation
2 Guides authored
2 Guide Comments
Great, Now where can I find this part to fix my laptop???
marrowii - Reply Share
where do I buy the new port???
rhena9 - Reply Share
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 67
All Time: 8,597
