Poin2 Chromebook 11 Battery Replacement
  1. Poin2 Chromebook 11 Battery Replacement, Battery: step 1, image 1 of 2 Poin2 Chromebook 11 Battery Replacement, Battery: step 1, image 2 of 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
    Ask FixBot
  2. Poin2 Chromebook 11 Battery Replacement: step 2, image 1 of 3 Poin2 Chromebook 11 Battery Replacement: step 2, image 2 of 3 Poin2 Chromebook 11 Battery Replacement: step 2, image 3 of 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
    Ask FixBot
  3. Poin2 Chromebook 11 Battery Replacement: step 3, image 1 of 3 Poin2 Chromebook 11 Battery Replacement: step 3, image 2 of 3 Poin2 Chromebook 11 Battery Replacement: step 3, image 3 of 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
    Ask FixBot
  4. Poin2 Chromebook 11 Battery Replacement: step 4, image 1 of 2 Poin2 Chromebook 11 Battery Replacement: step 4, image 2 of 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
    Ask FixBot
  5. Poin2 Chromebook 11 Battery Replacement: step 5, image 1 of 1
    • Lift the battery from the frame.
    Ask FixBot
To reassemble your Poin2 Chromebook 11, follow these instructions in reverse order.
2 other people completed this guide.
1 Guide Comment
An important piece of information missing is the battery replacement number.
a Google search brings up no references.
Marty Sharik - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,262
