Up to 20% off select tools
Poco X3 Pro Screen Replacement
Views: 47K
View statistics:
Past 24 Hours:
10
Past 7 Days:
103
Past 30 Days:
512
All Time:
46,922
Comments: 10
6 comments on steps, 4 guide comments.
Go to guide comments
Completed: 47
47 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace the screen on your Xiaomi Poco X3 Pro.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Due to the device’s design, you must remove the lithium-ion battery to access the display cables. If the battery was deformed during removal replace it with a new one—reusing a deformed battery is a potential safety hazard.
Before disassembling your device, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
    1. Poco X3 Pro Screen Replacement, Heat the back cover: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Poco X3 Pro Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Poco X3 Pro Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Poco X3 Pro Screen Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Poco X3 Pro Screen Replacement, Slice the adhesive: step 3, image 1 of 2 Poco X3 Pro Screen Replacement, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      Ask FixBot
    4. Poco X3 Pro Screen Replacement, Slice the adhesive: step 4, image 1 of 3 Poco X3 Pro Screen Replacement, Slice the adhesive: step 4, image 2 of 3 Poco X3 Pro Screen Replacement, Slice the adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Poco X3 Pro Screen Replacement: step 5, image 1 of 2 Poco X3 Pro Screen Replacement: step 5, image 2 of 2
      • Insert a fourth opening pick underneath the top left corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Poco X3 Pro Screen Replacement: step 6, image 1 of 2 Poco X3 Pro Screen Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
      Ask FixBot
    7. Poco X3 Pro Screen Replacement, Remove the back cover: step 7, image 1 of 2 Poco X3 Pro Screen Replacement, Remove the back cover: step 7, image 2 of 2
      • Remove the back cover.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Poco X3 Pro Screen Replacement, Unscrew the motherboard cover screws: step 8, image 1 of 1
      • Use a Phillips screwdriver of the correct size to remove the eleven 3.9 mm-long screws securing the motherboard cover.
      Ask FixBot
    2. Poco X3 Pro Screen Replacement, Pry up the motherboard cover: step 9, image 1 of 3 Poco X3 Pro Screen Replacement, Pry up the motherboard cover: step 9, image 2 of 3 Poco X3 Pro Screen Replacement, Pry up the motherboard cover: step 9, image 3 of 3
      • Insert the tip of an opening pick underneath the bottom right edge of the motherboard cover.
      • Slide the opening pick along the right edge of the motherboard cover to unhinge the plastic clips and pry it up.
      • Insert the opening pick underneath the top edge of the motherboard cover and pry it up.
      Ask FixBot
    3. Poco X3 Pro Screen Replacement, Remove the motherboard cover: step 10, image 1 of 2 Poco X3 Pro Screen Replacement, Remove the motherboard cover: step 10, image 2 of 2
      • Remove the motherboard cover.
      Ask FixBot
    4. Poco X3 Pro Screen Replacement, Disconnect the battery cable: step 11, image 1 of 2 Poco X3 Pro Screen Replacement, Disconnect the battery cable: step 11, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    1. Poco X3 Pro Screen Replacement, Disconnect the power and volume button flex cable: step 12, image 1 of 3 Poco X3 Pro Screen Replacement, Disconnect the power and volume button flex cable: step 12, image 2 of 3 Poco X3 Pro Screen Replacement, Disconnect the power and volume button flex cable: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • Use a spudger to disconnect the power and volume button flex cable by prying the connector straight up from its socket.
      • Use a pair of tweezers or your fingers to carefully fold the power and volume button flex cable to the side in order to get free access to the battery.
      Ask FixBot
    2. Poco X3 Pro Screen Replacement, Disconnect the interconnect cable: step 13, image 1 of 3 Poco X3 Pro Screen Replacement, Disconnect the interconnect cable: step 13, image 2 of 3 Poco X3 Pro Screen Replacement, Disconnect the interconnect cable: step 13, image 3 of 3
      • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
      • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
      • Fold the interconnect flex cable towards the charging port in order to get access to the battery pull tabs.
      • You might want to use a small piece of tape to temporarily stick the cables onto your working surface to avoid accidentally damaging them during the battery removal.
      Ask FixBot
    3. Poco X3 Pro Screen Replacement, Peel off the battery pull-tabs: step 14, image 1 of 3 Poco X3 Pro Screen Replacement, Peel off the battery pull-tabs: step 14, image 2 of 3 Poco X3 Pro Screen Replacement, Peel off the battery pull-tabs: step 14, image 3 of 3
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labelled with an A off the battery.
      • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labelled with a B off the battery.
      Ask FixBot
    4. Poco X3 Pro Screen Replacement, Remove the battery: step 15, image 1 of 3 Poco X3 Pro Screen Replacement, Remove the battery: step 15, image 2 of 3 Poco X3 Pro Screen Replacement, Remove the battery: step 15, image 3 of 3
      • Grab both pull–tab ends labelled with an A and pull up on the orange adhesive strip to lift the battery out of its recess and swing it up to an upright position.
      • Although these adhesive tabs are supposed to make the battery removal easier, they may require some force. In case you're having trouble removing the battery, you can apply a heated iOpener to the center of the display to loosen the adhesive underneath.
      • Peel the battery off the remaining adhesive.
      • Remove the battery.
      • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
      • In case you're replacing the adhesive sticker with a new one, peel the battery's adhesive sticker off the midframe and clean the relevant areas with isopropyl alcohol (>90%). Let the alcohol dry before installing new adhesive.
      Ask FixBot
    1. Poco X3 Pro Screen Replacement, Remove the battery adhesive sticker: step 16, image 1 of 2 Poco X3 Pro Screen Replacement, Remove the battery adhesive sticker: step 16, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to carefully peel the battery's adhesive sticker off the midframe.
      • In case you're having trouble to remove the sticker you can apply a heated iOpener or a heat gun to the screen to loosen it. Apply the iOpener for at least one minute.
      Ask FixBot
    2. Poco X3 Pro Screen Replacement, Disconnect the display flex cable: step 17, image 1 of 3 Poco X3 Pro Screen Replacement, Disconnect the display flex cable: step 17, image 2 of 3 Poco X3 Pro Screen Replacement, Disconnect the display flex cable: step 17, image 3 of 3
      • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
      • The display flex cable is adhered to the midframe with mild adhesive.
      • Use a pair of tweezers or your fingers to carefully peel the display flex cable off the midframe.
      Ask FixBot
    3. Poco X3 Pro Screen Replacement, Loosen the display adhesive: step 18, image 1 of 2 Poco X3 Pro Screen Replacement, Loosen the display adhesive: step 18, image 2 of 2
      • The rear camera module of the Poco X3 Pro sticks out of the midframe. In case you're unfamiliar with this kind of repair we recommend placing a lint free cloth or similar underneath during the following steps in order to avoid damaging the lenses.
      • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      • The protective adhesive of the Poco X3 Pro is very strong and it's hard to get underneath the display panel in the beginning. It is likely that you have to reapply the iOpener more than once. Once you get underneath the display panel it comes off very easily.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Ask FixBot
    4. Poco X3 Pro Screen Replacement, Insert an iFlex: step 19, image 1 of 2 Poco X3 Pro Screen Replacement, Insert an iFlex: step 19, image 2 of 2
      • Once the screen is warm to touch, apply a suction cup to the bottom edge of the screen.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an iFlex in the gap between the midframe and the screen.
      Ask FixBot
    5. Poco X3 Pro Screen Replacement, Insert an opening pick: step 20, image 1 of 2 Poco X3 Pro Screen Replacement, Insert an opening pick: step 20, image 2 of 2
      • Insert an opening pick above the iFlex.
      • Remove the iFlex.
      • Slide the opening pick to the bottom right corner of the screen to slice its adhesive. Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    6. Poco X3 Pro Screen Replacement, Slice the adhesive: step 21, image 1 of 2 Poco X3 Pro Screen Replacement, Slice the adhesive: step 21, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
      Ask FixBot
    7. Poco X3 Pro Screen Replacement: step 22, image 1 of 3 Poco X3 Pro Screen Replacement: step 22, image 2 of 3 Poco X3 Pro Screen Replacement: step 22, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun to for 1-2 minutes to reheat it.
      • Insert a third opening pick underneath the bottom left corner of the screen.
      • Slide the opening pick along the left edge of the screen to slice the adhesive. Leave it in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    8. Poco X3 Pro Screen Replacement: step 23, image 1 of 2 Poco X3 Pro Screen Replacement: step 23, image 2 of 2
      • When you slice near the front facing camera, insert only the tip of the opening pick to avoid damaging or smearing the camera.
      • Insert a fourth opening pick at the top left corner of the screen.
      • Slide the opening pick along the top edge of the phone to slice the adhesive.
      • Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
      Ask FixBot
    9. Poco X3 Pro Screen Replacement: step 24, image 1 of 2 Poco X3 Pro Screen Replacement: step 24, image 2 of 2
      • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
      • Do not try to remove the display all the way yet, the display cable is still threaded through the frame.
      Ask FixBot
    10. Poco X3 Pro Screen Replacement, Remove the screen: step 25, image 1 of 3 Poco X3 Pro Screen Replacement, Remove the screen: step 25, image 2 of 3 Poco X3 Pro Screen Replacement, Remove the screen: step 25, image 3 of 3
      • Thread the display flex cable through the gap in the midframe and remove the screen.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
47 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
4 Guide Comments
Forgot to mention the camera module and connectors
David O Shea - Reply Share
Wait... Never mind. Weird, the three little cameras were attached to the last housing in mine.
Anyone has any idea what could be the problem?
I have replaced the lcd screen and it works fine until i put motherboard cover back on.
When motherboard cover is on then it freezes or keeps restarting.
I have tried putting it on without any screws but the problem remains.
Tomislav - Reply Share
Any solution to this?
Charly3 - Reply Share
Past 24 Hours: 10
Past 7 Days: 103
Past 30 Days: 512
All Time: 46,922
