Pocket Knife Wooden Casing Replacement
  1. Pocket Knife Wooden Casing Replacement, Wooden Casing: step 1, image 1 of 2 Pocket Knife Wooden Casing Replacement, Wooden Casing: step 1, image 2 of 2
    • Trace the knife outline onto wood.
    Ask FixBot
  2. Pocket Knife Wooden Casing Replacement: step 2, image 1 of 2 Pocket Knife Wooden Casing Replacement: step 2, image 2 of 2
    • Cut out the outline of the wood.
    • Cut the height of the wood to the correct measurement.
    Ask FixBot
  3. Pocket Knife Wooden Casing Replacement: step 3, image 1 of 2 Pocket Knife Wooden Casing Replacement: step 3, image 2 of 2
    • Sand the wood so that it is smooth and free of hard edges.
    • For the best result, sand in the direction of the grain as much as possible.
    Ask FixBot
  4. Pocket Knife Wooden Casing Replacement: step 4, image 1 of 3 Pocket Knife Wooden Casing Replacement: step 4, image 2 of 3 Pocket Knife Wooden Casing Replacement: step 4, image 3 of 3
    • Stain and polish the wood so that it is reflects the other side of the knife.
    • Apply another coat after the first coat dries if you want a darker stain.
    • If you get the Stain and Polish on your skin, your skin might be stained for a few days. In this case, make sure you wash thoroughly; Stain and Polish is only toxic if it is ingested.
    Ask FixBot
  5. Pocket Knife Wooden Casing Replacement: step 5, image 1 of 2 Pocket Knife Wooden Casing Replacement: step 5, image 2 of 2
    • Drill four small holes that will go over the extruded parts of the knife.
    • You can accurately mark the positions of the holes by coloring the screw heads with sharpie then stamping them into the wood.
    Ask FixBot
  6. Pocket Knife Wooden Casing Replacement: step 6, image 1 of 3 Pocket Knife Wooden Casing Replacement: step 6, image 2 of 3 Pocket Knife Wooden Casing Replacement: step 6, image 3 of 3
    • Glue the wood to the knife and clean any hard edges or excess glue that comes from this step.
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 30
All Time: 835
