Playstation TV Motherboard Replacement
  1. Playstation TV Motherboard Replacement, Motherboard: step 1, image 1 of 2 Playstation TV Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Use the plastic spudger to pry up the bottom piece of the case to release the clips.
    Ask FixBot
  2. Playstation TV Motherboard Replacement: step 2, image 1 of 2 Playstation TV Motherboard Replacement: step 2, image 2 of 2
    • Remove the four 6 mm Phillips screws.
    • Remove the two Phillips #0 screws.
    Ask FixBot
  3. Playstation TV Motherboard Replacement: step 3, image 1 of 2 Playstation TV Motherboard Replacement: step 3, image 2 of 2
    • Remove the heat shield using the plastic opening tool.
    • Slide the tool around the edges until the shield is free.
    Ask FixBot
  4. Playstation TV Motherboard Replacement: step 4, image 1 of 2 Playstation TV Motherboard Replacement: step 4, image 2 of 2
    • Remove the last 6mm Phillips #0 screw from the motherboard.
    Ask FixBot
  5. Playstation TV Motherboard Replacement: step 5, image 1 of 2 Playstation TV Motherboard Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to pry up gently on the motherboard, and remove it.
    Ask FixBot
6 other people completed this guide.
Nick Dixon
275 Reputation
1 Guide authored
IUPUI, Team 3-1, Baechle Spring 2016 Member of IUPUI, Team 3-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G1
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 92
All Time: 5,392
