Up to 20% off select tools
Playstation Controller Fast Fix
Views: 9.2K
View statistics:
Past 24 Hours:
36
Past 7 Days:
224
Past 30 Days:
1,061
All Time:
9,197
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide provides a quick and practical fix for common controller issues, such as unresponsive buttons or minor stick problems. It emphasizes simple steps, minimal tools, and efficiency. Whether you're dealing with early signs of wear or a sudden malfunction, this fast fix aims to get your controller back to working condition without the need for costly replacements.
    1. Playstation Controller Fast Fix, Power Off and Disconnect: step 1, image 1 of 1
      • Turn off the controller and disconnect it.
      Ask FixBot
    2. Playstation Controller Fast Fix, Gather Tools: step 2, image 1 of 1
      • Prepare tools including a precision screwdriver set, plastic pry tool, tweezers, isopropyl alcohol, and cotton swabs.
      Ask FixBot
    3. Playstation Controller Fast Fix, Remove Outer Screws: step 3, image 1 of 1
      • Locate and remove all screws from the controller casing using a screwdriver. top and bottom.
      Ask FixBot
    4. Playstation Controller Fast Fix, Open the Controller Housing: step 4, image 1 of 1
      • Carefully pry open the controller using a plastic tool to avoid damaging components.
      Ask FixBot
    5. Playstation Controller Fast Fix, Disconnect Internal Components: step 5, image 1 of 1
      • Gently detach the battery and ribbon cables to access the motherboard, and then unscrew the motherboard retainer(black cover)
      Ask FixBot
    6. Playstation Controller Fast Fix, Locate the Analog Stick Module: step 6, image 1 of 1
      • Identify the joystick assembly attached to the circuit board. Note: look hard for this one. It's a bit small
      Ask FixBot
    7. Playstation Controller Fast Fix, Clean the Potentiometers: step 7, image 1 of 1
      • Apply isopropyl alcohol to the base of the analog stick and rotate it to remove dirt and other stuff. Note: be careful on how hard you clean with the swabs, and don't apply too much rubbing alcohol.
      Ask FixBot
    8. Playstation Controller Fast Fix, Reassemble and Test: step 8, image 1 of 2 Playstation Controller Fast Fix, Reassemble and Test: step 8, image 2 of 2
      • Reconnect all components, close the controller, and test it to ensure the stick drift is resolved. Note: since the battery was removed during the procedure, charging the controller is a must after putting it back together.
      Ask FixBot
5 other people completed this guide.
Author
with
Aaron Ruiz
323 Reputation
1 Guide authored
1 Guide Comment
How can i reconect my controler back to PS 4 ?????
Iosua Padurean - Reply Share
Past 24 Hours: 36
Past 7 Days: 224
Past 30 Days: 1,061
All Time: 9,197
