PlayStation scph-1001 Eye replacement
    1. PlayStation scph-1001 Eye replacement, Eye: step 1, image 1 of 2 PlayStation scph-1001 Eye replacement, Eye: step 1, image 2 of 2
      • This is your PlayStation before you do this teardown.
      Ask FixBot
    2. PlayStation scph-1001 Eye replacement: step 2, image 1 of 1
      • Now take the 5 black screws out of the case.
      Ask FixBot
    3. PlayStation scph-1001 Eye replacement: step 3, image 1 of 2 PlayStation scph-1001 Eye replacement: step 3, image 2 of 2
      • Now flip the system back over to its top. 'Be sure not to drop the top when you pick it up.
      Ask FixBot
    4. PlayStation scph-1001 Eye replacement: step 4, image 1 of 2 PlayStation scph-1001 Eye replacement: step 4, image 2 of 2
      • Pick up on the top case after you have flipped it over. This will have a little resistance but this should not break anything if you have all of the five screws out of the under case.
      Ask FixBot
    5. PlayStation scph-1001 Eye replacement: step 5, image 1 of 1
      • Then undo the piece holding in the ribbon cable. When you do this grab the side of the black piece holding it in place and pick it up slowly
      Ask FixBot
    6. PlayStation scph-1001 Eye replacement: step 6, image 1 of 2 PlayStation scph-1001 Eye replacement: step 6, image 2 of 2
      • Then undo the power cable and the eye Cable these should just lift right off.
      Ask FixBot
    7. PlayStation scph-1001 Eye replacement: step 7, image 1 of 2 PlayStation scph-1001 Eye replacement: step 7, image 2 of 2
      • Now just pick up on the eye and set it off to the side the reassembly
      Ask FixBot
7 other people completed this guide.
Walker wallace
1,056 Reputation
3 Guides authored
1 Guide Comment
Is this guide compatible with scph-1002 as well?
Markus Norstrøm - Reply Share
Past 24 Hours: 10
Past 7 Days: 48
Past 30 Days: 205
All Time: 5,748
