PlayStation Vita Right Button Board Replacement
    1. PlayStation Vita Right Button Board Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita Right Button Board Replacement, Case Separation: step 1, image 2 of 2
      • Power off and remove the memory card.
      • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
      Ask FixBot
    2. PlayStation Vita Right Button Board Replacement: step 2, image 1 of 3 PlayStation Vita Right Button Board Replacement: step 2, image 2 of 3 PlayStation Vita Right Button Board Replacement: step 2, image 3 of 3
      • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
      • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
      Ask FixBot
    3. PlayStation Vita Right Button Board Replacement: step 3, image 1 of 2 PlayStation Vita Right Button Board Replacement: step 3, image 2 of 2
      • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
      Ask FixBot
    4. PlayStation Vita Right Button Board Replacement: step 4, image 1 of 3 PlayStation Vita Right Button Board Replacement: step 4, image 2 of 3 PlayStation Vita Right Button Board Replacement: step 4, image 3 of 3
      • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
      • Continue working your way around the device gently prying it open.
      • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
      Ask FixBot
    5. PlayStation Vita Right Button Board Replacement: step 5, image 1 of 2 PlayStation Vita Right Button Board Replacement: step 5, image 2 of 2
      • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
      Ask FixBot
    6. PlayStation Vita Right Button Board Replacement: step 6, image 1 of 1
      • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
      Ask FixBot
    7. PlayStation Vita Right Button Board Replacement: step 7, image 1 of 1
      • Free the battery cable by gently prying up on the connection with a spudger.
      Ask FixBot
    8. PlayStation Vita Right Button Board Replacement: step 8, image 1 of 1
      • Separate the front and rear cases.
      Ask FixBot
    1. PlayStation Vita Right Button Board Replacement, Wireless Card: step 9, image 1 of 3 PlayStation Vita Right Button Board Replacement, Wireless Card: step 9, image 2 of 3 PlayStation Vita Right Button Board Replacement, Wireless Card: step 9, image 3 of 3
      • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
      • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
      Ask FixBot
    2. PlayStation Vita Right Button Board Replacement: step 10, image 1 of 2 PlayStation Vita Right Button Board Replacement: step 10, image 2 of 2
      • Hook the spudger beneath the tab on the wireless card casing and release the tab.
      • Peel up and remove the wireless card casing.
      Ask FixBot
    3. PlayStation Vita Right Button Board Replacement: step 11, image 1 of 2 PlayStation Vita Right Button Board Replacement: step 11, image 2 of 2
      • Remove the two 4.4mm Phillips #00 screws on the wireless card.
      • The wireless card will naturally pop out at an angle.
      • Pull out the wireless card.
      Ask FixBot
    1. PlayStation Vita Right Button Board Replacement, Right Shoulder Button: step 12, image 1 of 3 PlayStation Vita Right Button Board Replacement, Right Shoulder Button: step 12, image 2 of 3 PlayStation Vita Right Button Board Replacement, Right Shoulder Button: step 12, image 3 of 3
      • Pry up the right shoulder button casing with a spudger and set it aside.
      Ask FixBot
    2. PlayStation Vita Right Button Board Replacement: step 13, image 1 of 1
      • Remove the translucent, plastic right shoulder button cover.
      Ask FixBot
    3. PlayStation Vita Right Button Board Replacement: step 14, image 1 of 3 PlayStation Vita Right Button Board Replacement: step 14, image 2 of 3 PlayStation Vita Right Button Board Replacement: step 14, image 3 of 3
      Tool used on this step:
      Buy
      • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
      • Using tweezers, slide the flex cable out of the socket.
      Ask FixBot
    4. PlayStation Vita Right Button Board Replacement: step 15, image 1 of 2 PlayStation Vita Right Button Board Replacement: step 15, image 2 of 2
      • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
      Ask FixBot
    1. PlayStation Vita Right Button Board Replacement, Right Button Board: step 16, image 1 of 2 PlayStation Vita Right Button Board Replacement, Right Button Board: step 16, image 2 of 2
      • Using the pointy end of a spudger, detach the antenna cable on the right button board.
      • Remove the antenna cable.
      Ask FixBot
    2. PlayStation Vita Right Button Board Replacement: step 17, image 1 of 2 PlayStation Vita Right Button Board Replacement: step 17, image 2 of 2
      • Using a spudger, pry up and release the ZIF socket on the right button board.
      • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
      Ask FixBot
    3. PlayStation Vita Right Button Board Replacement: step 18, image 1 of 3 PlayStation Vita Right Button Board Replacement: step 18, image 2 of 3 PlayStation Vita Right Button Board Replacement: step 18, image 3 of 3
      Buy
      • Release the tab on the small flex cable socket by prying up the tab with a spudger.
      • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
      Ask FixBot
    4. PlayStation Vita Right Button Board Replacement: step 19, image 1 of 3 PlayStation Vita Right Button Board Replacement: step 19, image 2 of 3 PlayStation Vita Right Button Board Replacement: step 19, image 3 of 3
      • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
      • Remove the metal bracket, using a spudger as necessary to lift it out.
      Ask FixBot
    5. PlayStation Vita Right Button Board Replacement: step 20, image 1 of 3 PlayStation Vita Right Button Board Replacement: step 20, image 2 of 3 PlayStation Vita Right Button Board Replacement: step 20, image 3 of 3
      • Use a spudger to free the right button board by prying up from the bottom right corner of board.
      • Gently lift the right button board out.
      Ask FixBot
Brittany McCrigler
91,067 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
86,246 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 97
All Time: 10,013
