PlayStation Vita Rear Camera Replacement
    1. PlayStation Vita Rear Camera Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita Rear Camera Replacement, Case Separation: step 1, image 2 of 2
      • Power off and remove the memory card.
      • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
      Ask FixBot
    2. PlayStation Vita Rear Camera Replacement: step 2, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 2, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 2, image 3 of 3
      • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
      • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
      Ask FixBot
    3. PlayStation Vita Rear Camera Replacement: step 3, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 3, image 2 of 2
      • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
      Ask FixBot
    4. PlayStation Vita Rear Camera Replacement: step 4, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 4, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 4, image 3 of 3
      • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
      • Continue working your way around the device gently prying it open.
      • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
      Ask FixBot
    5. PlayStation Vita Rear Camera Replacement: step 5, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 5, image 2 of 2
      • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
      Ask FixBot
    6. PlayStation Vita Rear Camera Replacement: step 6, image 1 of 1
      • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
      Ask FixBot
    7. PlayStation Vita Rear Camera Replacement: step 7, image 1 of 1
      • Free the battery cable by gently prying up on the connection with a spudger.
      Ask FixBot
    8. PlayStation Vita Rear Camera Replacement: step 8, image 1 of 1
      • Separate the front and rear cases.
      Ask FixBot
    1. PlayStation Vita Rear Camera Replacement, Wireless Card: step 9, image 1 of 3 PlayStation Vita Rear Camera Replacement, Wireless Card: step 9, image 2 of 3 PlayStation Vita Rear Camera Replacement, Wireless Card: step 9, image 3 of 3
      • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
      • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
      Ask FixBot
    2. PlayStation Vita Rear Camera Replacement: step 10, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 10, image 2 of 2
      • Hook the spudger beneath the tab on the wireless card casing and release the tab.
      • Peel up and remove the wireless card casing.
      Ask FixBot
    3. PlayStation Vita Rear Camera Replacement: step 11, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 11, image 2 of 2
      • Remove the two 4.4mm Phillips #00 screws on the wireless card.
      • The wireless card will naturally pop out at an angle.
      • Pull out the wireless card.
      Ask FixBot
    1. PlayStation Vita Rear Camera Replacement, Right Shoulder Button: step 12, image 1 of 3 PlayStation Vita Rear Camera Replacement, Right Shoulder Button: step 12, image 2 of 3 PlayStation Vita Rear Camera Replacement, Right Shoulder Button: step 12, image 3 of 3
      • Pry up the right shoulder button casing with a spudger and set it aside.
      Ask FixBot
    2. PlayStation Vita Rear Camera Replacement: step 13, image 1 of 1
      • Remove the translucent, plastic right shoulder button cover.
      Ask FixBot
    3. PlayStation Vita Rear Camera Replacement: step 14, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 14, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 14, image 3 of 3
      Tool used on this step:
      Buy
      • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
      • Using tweezers, slide the flex cable out of the socket.
      Ask FixBot
    4. PlayStation Vita Rear Camera Replacement: step 15, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 15, image 2 of 2
      • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
      Ask FixBot
    1. PlayStation Vita Rear Camera Replacement, Right Button Board: step 16, image 1 of 2 PlayStation Vita Rear Camera Replacement, Right Button Board: step 16, image 2 of 2
      • Using the pointy end of a spudger, detach the antenna cable on the right button board.
      • Remove the antenna cable.
      Ask FixBot
    2. PlayStation Vita Rear Camera Replacement: step 17, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 17, image 2 of 2
      • Using a spudger, pry up and release the ZIF socket on the right button board.
      • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
      Ask FixBot
    3. PlayStation Vita Rear Camera Replacement: step 18, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 18, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 18, image 3 of 3
      Buy
      • Release the tab on the small flex cable socket by prying up the tab with a spudger.
      • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
      Ask FixBot
    4. PlayStation Vita Rear Camera Replacement: step 19, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 19, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 19, image 3 of 3
      • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
      • Remove the metal bracket, using a spudger as necessary to lift it out.
      Ask FixBot
    5. PlayStation Vita Rear Camera Replacement: step 20, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 20, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 20, image 3 of 3
      • Use a spudger to free the right button board by prying up from the bottom right corner of board.
      • Gently lift the right button board out.
      Ask FixBot
    1. PlayStation Vita Rear Camera Replacement, Left Shoulder Button: step 21, image 1 of 3 PlayStation Vita Rear Camera Replacement, Left Shoulder Button: step 21, image 2 of 3 PlayStation Vita Rear Camera Replacement, Left Shoulder Button: step 21, image 3 of 3
      • Pry up the left shoulder button casing with a spudger.
      • Remove the left shoulder button casing.
      Ask FixBot
    2. PlayStation Vita Rear Camera Replacement: step 22, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 22, image 2 of 2
      • Remove the translucent, plastic left shoulder button cover.
      Ask FixBot
    3. PlayStation Vita Rear Camera Replacement: step 23, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 23, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 23, image 3 of 3
      Buy
      • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
      • Be careful to not break off this small black tab!
      • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
      Ask FixBot
    4. PlayStation Vita Rear Camera Replacement: step 24, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 24, image 2 of 2
      • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
      Ask FixBot
    1. PlayStation Vita Rear Camera Replacement, Left Button Board: step 25, image 1 of 2 PlayStation Vita Rear Camera Replacement, Left Button Board: step 25, image 2 of 2
      • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
      • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
      Ask FixBot
    2. PlayStation Vita Rear Camera Replacement: step 26, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 26, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 26, image 3 of 3
      • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
      • Lift the SIM card reader off the back casing assembly.
      Ask FixBot
    3. PlayStation Vita Rear Camera Replacement: step 27, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 27, image 2 of 2
      Buy
      • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
      • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
      Ask FixBot
    4. PlayStation Vita Rear Camera Replacement: step 28, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 28, image 2 of 2
      • Use a spudger to lift up the tab on the large ZIF socket.
      • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
      Ask FixBot
    5. PlayStation Vita Rear Camera Replacement: step 29, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 29, image 2 of 2
      • Disconnect the white Wi-Fi antenna cable with a spudger.
      • Remove the Wi-Fi antenna cable.
      Ask FixBot
    6. PlayStation Vita Rear Camera Replacement: step 30, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 30, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 30, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
      • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
      • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
      Ask FixBot
    7. PlayStation Vita Rear Camera Replacement: step 31, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 31, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 31, image 3 of 3
      • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
      Ask FixBot
    1. PlayStation Vita Rear Camera Replacement, Rear Camera: step 32, image 1 of 2 PlayStation Vita Rear Camera Replacement, Rear Camera: step 32, image 2 of 2
      • Using the pointy end of a spudger, pry up and release the GPS antenna cable from the motherboard.
      • Remove the GPS antenna cable.
      Ask FixBot
    2. PlayStation Vita Rear Camera Replacement: step 33, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 33, image 2 of 2
      • Release the camera flex cable socket by prying up on the tab with a spudger.
      Ask FixBot
    3. PlayStation Vita Rear Camera Replacement: step 34, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 34, image 2 of 2
      • Using a spudger, gently pry up on the camera.
      • Work your way under the camera and along the camera flex cable, using the spudger to peel away the adhesive, freeing the camera.
      Ask FixBot
    4. PlayStation Vita Rear Camera Replacement: step 35, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 35, image 2 of 2
      • Carefully lift and remove the camera, sliding the flex cable out of the open connector socket.
      Ask FixBot
    5. PlayStation Vita Rear Camera Replacement: step 36, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 36, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the 6.3mm screw beneath the camera.
      • Lift and remove the metal camera bracket.
      Ask FixBot
    6. PlayStation Vita Rear Camera Replacement: step 37, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 37, image 2 of 2
      • With the help of a spudger, lift and release the tab on the blue flex cable socket.
      Ask FixBot
    7. PlayStation Vita Rear Camera Replacement: step 38, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 38, image 2 of 2
      Buy
      • Using tweezers, gently pull the blue power flex cable out of the socket, and rest it out of the way.
      Ask FixBot
    8. PlayStation Vita Rear Camera Replacement: step 39, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the two pink, 4.4mm screws securing the motherboard.
      Ask FixBot
    9. PlayStation Vita Rear Camera Replacement: step 40, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 40, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 40, image 3 of 3
      • Gently peel the rubber tab of the game port cover off the plastic casing pins.
      • Remove the game port cover.
      Ask FixBot
    10. PlayStation Vita Rear Camera Replacement: step 41, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 41, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 41, image 3 of 3
      • Gently peel the rubber tab of the accessory port cover off the plastic casing pins.
      • Remove the accessory port cover.
      Ask FixBot
    11. PlayStation Vita Rear Camera Replacement: step 42, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 42, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 42, image 3 of 3
      • Starting at the upper right hand corner, use a spudger to gently lift the motherboard out of the casing assembly.
      • The motherboard is still attached to the casing by a connector on the back of the motherboard. Do not pull the motherboard all the way out, or you may damage the connector.
      Ask FixBot
    12. PlayStation Vita Rear Camera Replacement: step 43, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 43, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 43, image 3 of 3
      • Lift the motherboard out and identify the OLED connector still attaching the motherboard to the casing.
      • Holding the Vita on its side, use a spudger to gently pry off the OLED connector from the motherboard.
      • Be sure to hold the motherboard while you release the connector as this will free the motherboard. If you are not holding the motherboard, it will fall.
      Ask FixBot
    13. PlayStation Vita Rear Camera Replacement: step 44, image 1 of 1
      • Completely separate the motherboard from the case. Set the case aside.
      Ask FixBot
    14. PlayStation Vita Rear Camera Replacement: step 45, image 1 of 2 PlayStation Vita Rear Camera Replacement: step 45, image 2 of 2
      • Flip the motherboard over so that the rear camera is facing you on the right.
      • Release the rear camera flex cable socket by prying up on the tab with a spudger. Leave the socket open.
      Ask FixBot
    15. PlayStation Vita Rear Camera Replacement: step 46, image 1 of 3 PlayStation Vita Rear Camera Replacement: step 46, image 2 of 3 PlayStation Vita Rear Camera Replacement: step 46, image 3 of 3
      • Gently pull the rear camera out of the flex cable socket.
      Ask FixBot
3 other people completed this guide.
Brittany McCrigler
91,067 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
86,210 Guides authored
1 Guide Comment
This is not it's rear-facing camera though - it is it's front-facing camera.
iFixOmaha LLC - Reply Share
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 89
All Time: 6,972
