PlayStation Vita Camera Replacement
    1. PlayStation Vita Camera Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita Camera Replacement, Case Separation: step 1, image 2 of 2
      • Power off and remove the memory card.
      • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
      Ask FixBot
    2. PlayStation Vita Camera Replacement: step 2, image 1 of 3 PlayStation Vita Camera Replacement: step 2, image 2 of 3 PlayStation Vita Camera Replacement: step 2, image 3 of 3
      • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
      • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
      Ask FixBot
    3. PlayStation Vita Camera Replacement: step 3, image 1 of 2 PlayStation Vita Camera Replacement: step 3, image 2 of 2
      • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
      Ask FixBot
    4. PlayStation Vita Camera Replacement: step 4, image 1 of 3 PlayStation Vita Camera Replacement: step 4, image 2 of 3 PlayStation Vita Camera Replacement: step 4, image 3 of 3
      • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
      • Continue working your way around the device gently prying it open.
      • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
      Ask FixBot
    5. PlayStation Vita Camera Replacement: step 5, image 1 of 2 PlayStation Vita Camera Replacement: step 5, image 2 of 2
      • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
      Ask FixBot
    6. PlayStation Vita Camera Replacement: step 6, image 1 of 1
      • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
      Ask FixBot
    7. PlayStation Vita Camera Replacement: step 7, image 1 of 1
      • Free the battery cable by gently prying up on the connection with a spudger.
      Ask FixBot
    8. PlayStation Vita Camera Replacement: step 8, image 1 of 1
      • Separate the front and rear cases.
      Ask FixBot
    1. PlayStation Vita Camera Replacement, Camera: step 9, image 1 of 2 PlayStation Vita Camera Replacement, Camera: step 9, image 2 of 2
      • Release the camera flex cable socket by prying up on the tab with a spudger. Leave the socket open.
      Ask FixBot
    2. PlayStation Vita Camera Replacement: step 10, image 1 of 3 PlayStation Vita Camera Replacement: step 10, image 2 of 3 PlayStation Vita Camera Replacement: step 10, image 3 of 3
      • Using a spudger, gently pry up the camera.
      • Work your way under the camera and along the camera flex cable, using the pointy tip of the spudger to peel away the adhesive, freeing the camera.
      • Carefully lift and remove the camera.
      Ask FixBot
5 other people completed this guide.
Brittany McCrigler
91,067 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 99
All Time: 11,575
