PlayStation Vita Battery Replacement
    1. PlayStation Vita Battery Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita Battery Replacement, Case Separation: step 1, image 2 of 2
      • Power off and remove the memory card.
      • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
      Ask FixBot
    2. PlayStation Vita Battery Replacement: step 2, image 1 of 3 PlayStation Vita Battery Replacement: step 2, image 2 of 3 PlayStation Vita Battery Replacement: step 2, image 3 of 3
      • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
      • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
      Ask FixBot
    3. PlayStation Vita Battery Replacement: step 3, image 1 of 2 PlayStation Vita Battery Replacement: step 3, image 2 of 2
      • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
      Ask FixBot
    4. PlayStation Vita Battery Replacement: step 4, image 1 of 3 PlayStation Vita Battery Replacement: step 4, image 2 of 3 PlayStation Vita Battery Replacement: step 4, image 3 of 3
      • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
      • Continue working your way around the device gently prying it open.
      • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
      Ask FixBot
    5. PlayStation Vita Battery Replacement: step 5, image 1 of 2 PlayStation Vita Battery Replacement: step 5, image 2 of 2
      • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
      Ask FixBot
    6. PlayStation Vita Battery Replacement: step 6, image 1 of 1
      • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
      Ask FixBot
    7. PlayStation Vita Battery Replacement: step 7, image 1 of 1
      • Free the battery cable by gently prying up on the connection with a spudger.
      Ask FixBot
    8. PlayStation Vita Battery Replacement: step 8, image 1 of 1
      • Separate the front and rear cases.
      Ask FixBot
    1. PlayStation Vita Battery Replacement, Battery: step 9, image 1 of 2 PlayStation Vita Battery Replacement, Battery: step 9, image 2 of 2
      • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
      • The easiest access to the battery cable retainer is where the battery cable comes out.
      • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
      Ask FixBot
    2. PlayStation Vita Battery Replacement: step 10, image 1 of 2 PlayStation Vita Battery Replacement: step 10, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
      • Remove the plastic battery retaining bar.
      Ask FixBot
    3. PlayStation Vita Battery Replacement: step 11, image 1 of 3 PlayStation Vita Battery Replacement: step 11, image 2 of 3 PlayStation Vita Battery Replacement: step 11, image 3 of 3
      • Using your finger or a spudger, lift the battery out and remove it.
      • Guide the battery wires through the hole in the back casing as you remove the battery.
      Ask FixBot
165 other people completed this guide.
Brittany McCrigler
91,067 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
86,229 Guides authored
33 Guide Comments
Great guide. Only problem is this takes very steady hands (something i do not have)
chavis0704 - Reply Share
how do i know what persent my battery is at
jewon - Reply Share
Jewon today we have a hack for psvita 3.60 version ONLY !! this allow u download a VPK file that says how much persent your battery is at
brunosapo - Reply Share
With your Vita connected to your PC and the Content manager application running, on windows right click on the vita and then properties and the battery percentage will show up.
Matthew Michand - Reply Share
Great guide. Thanks for writing it!
Reiaze - Reply Share
Past 24 Hours: 94
Past 7 Days: 636
Past 30 Days: 2,840
All Time: 343,995
