PlayStation VR Processor Unit Thermal Pad / Fan Replacement
  1. PlayStation VR Processor Unit Thermal Pad / Fan Replacement, Processor Unit Thermal Pad: step 1, image 1 of 2 PlayStation VR Processor Unit Thermal Pad / Fan Replacement, Processor Unit Thermal Pad: step 1, image 2 of 2
    • Place the PlayStation VR processor unit with the I/O (back) side facing up.
    • Peel the sticker up with a fingernail or a pry tool.
    • Remove the single J0 screw.
    • Place the screw in a parts tray to keep it organized.
    Ask FixBot
  2. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 2, image 1 of 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 2, image 2 of 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 2, image 3 of 3
    • Use an opening tool to separate the bottom cover from the top.
    Ask FixBot
  3. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 3, image 1 of 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 3, image 2 of 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the eight J0 screws.
    • Place the screws in the parts tray
    • Use your tweezers to disconnect the fan connector from the motherboard
    • If the fan needs to be replaced, stop here and follow in reverse.
    • Fan details.
    • Brand: Nidec
    • Model and dimensions: U35x05m 52aa7-56j14
    • Power: 5v and .18a
    Ask FixBot
  4. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 4, image 1 of 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 4, image 2 of 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: step 4, image 3 of 3
    • Use a spudger or a fingernail to lift the pcb in the direction highlighted
    • Gently separate the metal plate from pcb
    • Replace the thermal paste if needed.
    • Use a fingernail or a pry tool to see if the thermal pad is still soft. that means it still conducts heat. if hard, remove and replace the thermal pad
    Ask FixBot
4 other people completed this guide.
Kalib Ellery
588 Reputation
2 Guides authored
3 Guide Comments
Hi, is thermal pads being dry could be the reason for this processing unit not turning on? It lits the light for quick millisecond and goes out as i connect the barrel jack. :( I couldn't find any fix yet
Chandu Samarasekara - Reply Share
Is it neccessary to replace the thermal pad with another pad , or may I use normal thermal paste?
DasNexus - Reply Share
It must be replaced with another new thermal pad of the same thickness, in this case a 2mm pad. If you use thermal paste, there will be a lot of space between the heatsink and the chip, which could cause failures and overheating.
Rixson Perez - Reply Share
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 83
All Time: 4,535
