Up to 20% off select tools
PlayStation VR Microphone Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
70
All Time:
1,882
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 35 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide shows you how to disassemble and replace the microphone on your Playstation VR headset.
    1. PlayStation VR Microphone Replacement, LED Light Tracker: step 1, image 1 of 3 PlayStation VR Microphone Replacement, LED Light Tracker: step 1, image 2 of 3 PlayStation VR Microphone Replacement, LED Light Tracker: step 1, image 3 of 3
      • Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
      Ask FixBot
    2. PlayStation VR Microphone Replacement: step 2, image 1 of 2 PlayStation VR Microphone Replacement: step 2, image 2 of 2
      • Unscrew four 13 mm screws with a PH #000 screwdriver.
      Ask FixBot
    3. PlayStation VR Microphone Replacement: step 3, image 1 of 2 PlayStation VR Microphone Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
      Ask FixBot
    4. PlayStation VR Microphone Replacement: step 4, image 1 of 3 PlayStation VR Microphone Replacement: step 4, image 2 of 3 PlayStation VR Microphone Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to pry the top white plastic panel free from the headset.
      • Do not try to remove the bottom plastic panel. There is a screw attaching it that must be removed first.
      • There may be a small amount of adhesive attaching the top panel to the headset, in which case you may need to use a bit more force to remove the panel.
      Ask FixBot
    5. PlayStation VR Microphone Replacement: step 5, image 1 of 1
      • Flip the headset over.
      • Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
      Ask FixBot
    6. PlayStation VR Microphone Replacement: step 6, image 1 of 3 PlayStation VR Microphone Replacement: step 6, image 2 of 3 PlayStation VR Microphone Replacement: step 6, image 3 of 3
      • Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
      • There is adhesive attaching the panel to the headset, in which case it will take more force to remove the panel.
      Ask FixBot
    7. PlayStation VR Microphone Replacement: step 7, image 1 of 3 PlayStation VR Microphone Replacement: step 7, image 2 of 3 PlayStation VR Microphone Replacement: step 7, image 3 of 3
      • Unscrew the two 7 mm screws from the top of the headset.
      Ask FixBot
    8. PlayStation VR Microphone Replacement: step 8, image 1 of 3 PlayStation VR Microphone Replacement: step 8, image 2 of 3 PlayStation VR Microphone Replacement: step 8, image 3 of 3
      • Using your fingers, carefully pry the black front panel free from the headset.
      • We recommend that you start the removal from the sides by pulling them forward.
      • There is adhesive holding the front panel in place, which means you will need a bit of extra force to remove it.
      Ask FixBot
    9. PlayStation VR Microphone Replacement: step 9, image 1 of 1
      • Unscrew the four silver 6 mm screws in each corner using a PH #000 screwdriver.
      Ask FixBot
    10. PlayStation VR Microphone Replacement: step 10, image 1 of 3 PlayStation VR Microphone Replacement: step 10, image 2 of 3 PlayStation VR Microphone Replacement: step 10, image 3 of 3
      • Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
      • Carefully pull the end of the white ribbon connector from its slot.
      • Be careful not to damage or dirty the ribbon connector.
      Ask FixBot
    11. PlayStation VR Microphone Replacement: step 11, image 1 of 2 PlayStation VR Microphone Replacement: step 11, image 2 of 2
      • Unhitch the yellow led connector ribbon and move it aside.
      Ask FixBot
    12. PlayStation VR Microphone Replacement: step 12, image 1 of 3 PlayStation VR Microphone Replacement: step 12, image 2 of 3 PlayStation VR Microphone Replacement: step 12, image 3 of 3
      • Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
      • Remove the yellow LED ribbons and black plastic connecting piece from the headset.
      Ask FixBot
    1. PlayStation VR Microphone Replacement, Microphone: step 13, image 1 of 1
      • Pinch the small white cable connector and unplug it from the motherboard.
      • The microphone will be attached to the white cable connector on the bottom right of the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 70
All Time: 1,882
