Up to 20% off select tools
PlayStation VR LED Light Tracker Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
129
All Time:
5,099
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will provide instructions for removing and replacing the LED of the PlayStation VR Headset. This will require you to open the headset up, which may seem daunting at first, but can easily be done.
    1. PlayStation VR LED Light Tracker Replacement, LED Light Tracker: step 1, image 1 of 3 PlayStation VR LED Light Tracker Replacement, LED Light Tracker: step 1, image 2 of 3 PlayStation VR LED Light Tracker Replacement, LED Light Tracker: step 1, image 3 of 3
      • Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
      Ask FixBot
    2. PlayStation VR LED Light Tracker Replacement: step 2, image 1 of 2 PlayStation VR LED Light Tracker Replacement: step 2, image 2 of 2
      • Unscrew four 13 mm screws with a PH #000 screwdriver.
      Ask FixBot
    3. PlayStation VR LED Light Tracker Replacement: step 3, image 1 of 2 PlayStation VR LED Light Tracker Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
      Ask FixBot
    4. PlayStation VR LED Light Tracker Replacement: step 4, image 1 of 3 PlayStation VR LED Light Tracker Replacement: step 4, image 2 of 3 PlayStation VR LED Light Tracker Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to pry the top white plastic panel free from the headset.
      • Do not try to remove the bottom plastic panel. There is a screw attaching it that must be removed first.
      • There may be a small amount of adhesive attaching the top panel to the headset, in which case you may need to use a bit more force to remove the panel.
      Ask FixBot
    5. PlayStation VR LED Light Tracker Replacement: step 5, image 1 of 1
      • Flip the headset over.
      • Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
      Ask FixBot
    6. PlayStation VR LED Light Tracker Replacement: step 6, image 1 of 3 PlayStation VR LED Light Tracker Replacement: step 6, image 2 of 3 PlayStation VR LED Light Tracker Replacement: step 6, image 3 of 3
      • Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
      • There is adhesive attaching the panel to the headset, in which case it will take more force to remove the panel.
      Ask FixBot
    7. PlayStation VR LED Light Tracker Replacement: step 7, image 1 of 3 PlayStation VR LED Light Tracker Replacement: step 7, image 2 of 3 PlayStation VR LED Light Tracker Replacement: step 7, image 3 of 3
      • Unscrew the two 7 mm screws from the top of the headset.
      Ask FixBot
    8. PlayStation VR LED Light Tracker Replacement: step 8, image 1 of 3 PlayStation VR LED Light Tracker Replacement: step 8, image 2 of 3 PlayStation VR LED Light Tracker Replacement: step 8, image 3 of 3
      • Using your fingers, carefully pry the black front panel free from the headset.
      • We recommend that you start the removal from the sides by pulling them forward.
      • There is adhesive holding the front panel in place, which means you will need a bit of extra force to remove it.
      Ask FixBot
    9. PlayStation VR LED Light Tracker Replacement: step 9, image 1 of 1
      • Unscrew the four silver 6 mm screws in each corner using a PH #000 screwdriver.
      Ask FixBot
    10. PlayStation VR LED Light Tracker Replacement: step 10, image 1 of 3 PlayStation VR LED Light Tracker Replacement: step 10, image 2 of 3 PlayStation VR LED Light Tracker Replacement: step 10, image 3 of 3
      • Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
      • Carefully pull the end of the white ribbon connector from its slot.
      • Be careful not to damage or dirty the ribbon connector.
      Ask FixBot
    11. PlayStation VR LED Light Tracker Replacement: step 11, image 1 of 2 PlayStation VR LED Light Tracker Replacement: step 11, image 2 of 2
      • Unhitch the yellow led connector ribbon and move it aside.
      Ask FixBot
    12. PlayStation VR LED Light Tracker Replacement: step 12, image 1 of 3 PlayStation VR LED Light Tracker Replacement: step 12, image 2 of 3 PlayStation VR LED Light Tracker Replacement: step 12, image 3 of 3
      • Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
      • Remove the yellow LED ribbons and black plastic connecting piece from the headset.
      Ask FixBot
Author
with
Sarah Shand
1,996 Reputation
7 Guides authored
USF Tampa, Team S3-G1, Sullivan Spring 2017 Member of USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Members
84 Guides authored
1 Guide Comment
where can I buy the LED lights for it??
Jordi - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 129
All Time: 5,099
