PlayStation TV Thermal Pad Replacement
    1. PlayStation TV Thermal Pad Replacement, Motherboard: step 1, image 1 of 2 PlayStation TV Thermal Pad Replacement, Motherboard: step 1, image 2 of 2
      • Use the plastic spudger to pry up the bottom piece of the case to release the clips.
      Ask FixBot
    2. PlayStation TV Thermal Pad Replacement: step 2, image 1 of 2 PlayStation TV Thermal Pad Replacement: step 2, image 2 of 2
      • Remove the four 6 mm Phillips screws.
      • Remove the two Phillips #0 screws.
      Ask FixBot
    3. PlayStation TV Thermal Pad Replacement: step 3, image 1 of 2 PlayStation TV Thermal Pad Replacement: step 3, image 2 of 2
      • Remove the heat shield using the plastic opening tool.
      • Slide the tool around the edges until the shield is free.
      Ask FixBot
    4. PlayStation TV Thermal Pad Replacement: step 4, image 1 of 2 PlayStation TV Thermal Pad Replacement: step 4, image 2 of 2
      • Remove the last 6mm Phillips #0 screw from the motherboard.
      Ask FixBot
    5. PlayStation TV Thermal Pad Replacement: step 5, image 1 of 2 PlayStation TV Thermal Pad Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to pry up gently on the motherboard, and remove it.
      Ask FixBot
    1. PlayStation TV Thermal Pad Replacement, Thermal Pad: step 6, image 1 of 2 PlayStation TV Thermal Pad Replacement, Thermal Pad: step 6, image 2 of 2
      • Remove the old thermal pad with an ESD safe tool, like a Jimmy.
      Ask FixBot
    2. PlayStation TV Thermal Pad Replacement: step 7, image 1 of 2 PlayStation TV Thermal Pad Replacement: step 7, image 2 of 2
      • Wipe down the area where the old thermal pads were located with rubbing alcohol.
      • It is important that the area be as clean as possible.
      Ask FixBot
3 other people completed this guide.
Theodore Hesse
145 Reputation
1 Guide authored
IUPUI, Team 3-1, Baechle Spring 2016 Member of IUPUI, Team 3-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G1
4 Members
24 Guides authored
2 Guide Comments
Photos for steps 6 through 9 will be posted soon!
Luk Davis - Reply Share
Do you replace the thermal pad? Your directions do not state where to do this, and if so what part and size do you recommend?
Daimonion - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 99
All Time: 2,813
