PlayStation Start and Select Buttons Replacement
    1. PlayStation Start and Select Buttons Replacement, Start and Select Buttons: step 1, image 1 of 1
      • Before you begin, unplug your controller and console to avoid accidentally turning it on during disassembly.
      Ask FixBot
    2. PlayStation Start and Select Buttons Replacement: step 2, image 1 of 3 PlayStation Start and Select Buttons Replacement: step 2, image 2 of 3 PlayStation Start and Select Buttons Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the five 7.2 mm screws securing the rear cover.
      Ask FixBot
    3. PlayStation Start and Select Buttons Replacement: step 3, image 1 of 3 PlayStation Start and Select Buttons Replacement: step 3, image 2 of 3 PlayStation Start and Select Buttons Replacement: step 3, image 3 of 3
      • Gently push the rear cover towards the front of the #2 trigger buttons.
      • Lift the rear cover.
      • The #2 trigger buttons may come off when removing the cover.
      Ask FixBot
    4. PlayStation Start and Select Buttons Replacement: step 4, image 1 of 2 PlayStation Start and Select Buttons Replacement: step 4, image 2 of 2
      • Lift the battery and set it beside the controller, with care not to strain the wires.
      • Use a Phillips #1 screwdriver to remove the single 7.2 mm screw securing the motherboard.
      Ask FixBot
    5. PlayStation Start and Select Buttons Replacement: step 5, image 1 of 2 PlayStation Start and Select Buttons Replacement: step 5, image 2 of 2
      • Unclip the vibrating motors.
      • Be careful not to break the black and red wires connected to the motherboard. They are very fragile!
      Ask FixBot
    6. PlayStation Start and Select Buttons Replacement: step 6, image 1 of 2 PlayStation Start and Select Buttons Replacement: step 6, image 2 of 2
      • Lift off the plastic housing holding the motherboard, battery, and vibrating motors.
      Ask FixBot
    7. PlayStation Start and Select Buttons Replacement: step 7, image 1 of 3 PlayStation Start and Select Buttons Replacement: step 7, image 2 of 3 PlayStation Start and Select Buttons Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the rubber buttons with a pair of tweezers.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 148
All Time: 3,748
