Up to 20% off select tools
PlayStation Portal Back Shell Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
93
Past 30 Days:
283
All Time:
4,282
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove and replace the back shell (aka rear case, back housing, or bottom shell) for your PlayStation Portal. You'll need to remove this part for most Portal repairs.
    1. PlayStation Portal Back Shell Replacement, Power off your PlayStation Portal: step 1, image 1 of 2 PlayStation Portal Back Shell Replacement, Power off your PlayStation Portal: step 1, image 2 of 2
      • Before you begin repairs, power off your PlayStation Portal and unplug any cables.
      Ask FixBot
    1. PlayStation Portal Back Shell Replacement, Pry up the L1 bumper: step 2, image 1 of 3 PlayStation Portal Back Shell Replacement, Pry up the L1 bumper: step 2, image 2 of 3 PlayStation Portal Back Shell Replacement, Pry up the L1 bumper: step 2, image 3 of 3
      • Both bumpers are held in place with clips.
      • Rest a finger over the L1 bumper to prevent it from flying off when you pry.
      • Insert the flat end of a spudger between the top edge of the bumper and the white shell.
      • Pry up to unclip the bumper.
      • Slide the spudger along the seam to release any remaining clips.
      Ask FixBot
    2. PlayStation Portal Back Shell Replacement: step 3, image 1 of 1
      • Remove the L1 bumper.
      Ask FixBot
    3. PlayStation Portal Back Shell Replacement, Pry up the R1 bumper: step 4, image 1 of 3 PlayStation Portal Back Shell Replacement, Pry up the R1 bumper: step 4, image 2 of 3 PlayStation Portal Back Shell Replacement, Pry up the R1 bumper: step 4, image 3 of 3
      • Repeat the procedure to pry up and remove the R1 bumper.
      Ask FixBot
    4. PlayStation Portal Back Shell Replacement, Reassembly information: step 5, image 1 of 3 PlayStation Portal Back Shell Replacement, Reassembly information: step 5, image 2 of 3 PlayStation Portal Back Shell Replacement, Reassembly information: step 5, image 3 of 3
      • To install a bumper during reassembly:
      • Align the bumper into its slot.
      • Use a finger to press the bumper down firmly until it clicks into place.
      Ask FixBot
    1. PlayStation Portal Back Shell Replacement, Loosen the left joystick trim strip: step 6, image 1 of 2 PlayStation Portal Back Shell Replacement, Loosen the left joystick trim strip: step 6, image 2 of 2
      • Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
      • Twist the opening pick to release the bottom clip.
      Ask FixBot
    2. PlayStation Portal Back Shell Replacement: step 7, image 1 of 3 PlayStation Portal Back Shell Replacement: step 7, image 2 of 3 PlayStation Portal Back Shell Replacement: step 7, image 3 of 3
      • Insert the tip of an opening pick underneath the outer edge of the trim strip.
      • Slide the opening pick along the edge to release the clips.
      Ask FixBot
    3. PlayStation Portal Back Shell Replacement: step 8, image 1 of 2 PlayStation Portal Back Shell Replacement: step 8, image 2 of 2
      • Insert the tip of an opening pick under the inner edge of the strip.
      Ask FixBot
    4. PlayStation Portal Back Shell Replacement: step 9, image 1 of 2 PlayStation Portal Back Shell Replacement: step 9, image 2 of 2
      • Grasp the bottom edge of the trim strip and slowly lift to release any remaining clips.
      • If the strip feels stuck, twist or shift the strip sideways to help release any stubborn clips.
      Ask FixBot
    5. PlayStation Portal Back Shell Replacement, Remove the left joystick trim strip: step 10, image 1 of 2 PlayStation Portal Back Shell Replacement, Remove the left joystick trim strip: step 10, image 2 of 2
      • Lift and remove the left joystick trim strip.
      Ask FixBot
    6. PlayStation Portal Back Shell Replacement, Remove the right joystick trim strip: step 11, image 1 of 3 PlayStation Portal Back Shell Replacement, Remove the right joystick trim strip: step 11, image 2 of 3 PlayStation Portal Back Shell Replacement, Remove the right joystick trim strip: step 11, image 3 of 3
      • Repeat the procedure to unclip and remove the right joystick trim strip.
      Ask FixBot
    7. PlayStation Portal Back Shell Replacement, Reassembly information: step 12, image 1 of 2 PlayStation Portal Back Shell Replacement, Reassembly information: step 12, image 2 of 2
      • To reattach a trim strip during reassembly:
      • Use your fingers to align and clip the top edge in place.
      • Firmly press along the remaining edges to clip the strip in place.
      Ask FixBot
    1. PlayStation Portal Back Shell Replacement, Remove the back shell screws: step 13, image 1 of 2 PlayStation Portal Back Shell Replacement, Remove the back shell screws: step 13, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws at the bottom tips of each grip.
      • You may need to peel off some tamper-evident stickers to access the screws.
      Ask FixBot
    2. PlayStation Portal Back Shell Replacement: step 14, image 1 of 2 PlayStation Portal Back Shell Replacement: step 14, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the top corners of the shell.
      Ask FixBot
    3. PlayStation Portal Back Shell Replacement, Back shell information: step 15, image 1 of 1
      • The back shell is still secured with numerous clips. The next few steps will show how to unclip the shell while reducing the chance of damaging the clips.
      Ask FixBot
    4. PlayStation Portal Back Shell Replacement, Unclip the back shell: step 16, image 1 of 2 PlayStation Portal Back Shell Replacement, Unclip the back shell: step 16, image 2 of 2
      • Push the flat edge of a spudger into the back shell's left, inner seam.
      • This releases the clip in that area while flexing the shell slightly, creating a larger outer seam.
      • Keep the spudger inserted in the seam.
      Ask FixBot
    5. PlayStation Portal Back Shell Replacement: step 17, image 1 of 3 PlayStation Portal Back Shell Replacement: step 17, image 2 of 3 PlayStation Portal Back Shell Replacement: step 17, image 3 of 3
      • Insert the tip of an opening pick into the shell's left, outer seam.
      • Slide the pick along the seam to release the clips securing the edge.
      • Keep a pick in the seam to prevent the shell from clipping back together.
      Ask FixBot
    6. PlayStation Portal Back Shell Replacement: step 18, image 1 of 2 PlayStation Portal Back Shell Replacement: step 18, image 2 of 2
      • Remove the spudger from the inner seam.
      Ask FixBot
    7. PlayStation Portal Back Shell Replacement: step 19, image 1 of 3 PlayStation Portal Back Shell Replacement: step 19, image 2 of 3 PlayStation Portal Back Shell Replacement: step 19, image 3 of 3
      • Repeat the previous three steps on the right side of the Portal to release the clips along the right edge.
      Ask FixBot
    8. PlayStation Portal Back Shell Replacement: step 20, image 1 of 2 PlayStation Portal Back Shell Replacement: step 20, image 2 of 2
      • Carefully flip your Portal over.
      • Grasp the top edge of the back shell, near a corner.
      • Gently pull the top edge away until you feel the clips release in that corner.
      Ask FixBot
    9. PlayStation Portal Back Shell Replacement: step 21, image 1 of 2 PlayStation Portal Back Shell Replacement: step 21, image 2 of 2
      • Pull along the top edge to release all the top edge clips.
      Ask FixBot
    10. PlayStation Portal Back Shell Replacement: step 22, image 1 of 2 PlayStation Portal Back Shell Replacement: step 22, image 2 of 2
      • Grasp the bottom edge of the back shell, near the center.
      • Pull away with firm force to release the clips securing the bottom edge.
      Ask FixBot
    11. PlayStation Portal Back Shell Replacement, Remove the back shell: step 23, image 1 of 2 PlayStation Portal Back Shell Replacement, Remove the back shell: step 23, image 2 of 2
      • Remove the back shell.
      Ask FixBot
    12. PlayStation Portal Back Shell Replacement, Reassembly information: step 24, image 1 of 3 PlayStation Portal Back Shell Replacement, Reassembly information: step 24, image 2 of 3 PlayStation Portal Back Shell Replacement, Reassembly information: step 24, image 3 of 3
      • To clip the back shell in place during reassembly:
      • Align the corners near the trigger buttons first.
      • Firmly press around the entire perimeter to clip the shell back in place.
      Ask FixBot
Arthur Shi
354,406 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 93
Past 30 Days: 283
All Time: 4,282
