PlayStation One Mother Board Replacement
Views: 17K
View statistics:
Past 24 Hours:
5
Past 7 Days:
51
Past 30 Days:
251
All Time:
16,801
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This will guide you in replacing the Mother board of a PlayStation One.
Tools
    1. PlayStation One Mother Board Replacement, Upper Case: step 1, image 1 of 1
      • Remove all cables plugged into the PlayStation.
      Ask FixBot
    2. PlayStation One Mother Board Replacement: step 2, image 1 of 2 PlayStation One Mother Board Replacement: step 2, image 2 of 2
      • Flip over the PlayStation and remove the six screws from the bottom.
      Ask FixBot
    3. PlayStation One Mother Board Replacement: step 3, image 1 of 1
      • Flip the PlayStation back.
      • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
      Ask FixBot
    4. PlayStation One Mother Board Replacement: step 4, image 1 of 2 PlayStation One Mother Board Replacement: step 4, image 2 of 2
      • Lift up and remove the upper case.
      Ask FixBot
    1. PlayStation One Mother Board Replacement, Laser Assembly: step 5, image 1 of 3 PlayStation One Mother Board Replacement, Laser Assembly: step 5, image 2 of 3 PlayStation One Mother Board Replacement, Laser Assembly: step 5, image 3 of 3
      • Disconnect the cables from the PSone’s board.
      • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
      Ask FixBot
    1. PlayStation One Mother Board Replacement, Mother Board: step 6, image 1 of 2 PlayStation One Mother Board Replacement, Mother Board: step 6, image 2 of 2
      • remove the metal plate
      Ask FixBot
    2. PlayStation One Mother Board Replacement: step 7, image 1 of 3 PlayStation One Mother Board Replacement: step 7, image 2 of 3 PlayStation One Mother Board Replacement: step 7, image 3 of 3
      • remove the mother board by lifting the back.
      • if you're having a hard time removing it, use your nail and lift the second controller port.
      Ask FixBot
18 other people completed this guide.
Marjorie
2,493 Reputation
11 Guides authored
1 Guide Comment
I think that the GPU in my PS One is going bad (screen flickers green and pink on occasion but it is becoming more frequent). Would replacing the motherboard fix this? That is, is the GPU stored on the motherboard?
Eric Rosenberg - Reply Share
Past 24 Hours: 5
Past 7 Days: 51
Past 30 Days: 251
All Time: 16,801
