Up to 20% off select tools
PlayStation One Lower Case Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
36
Past 30 Days:
156
All Time:
6,387
Comments: 2
2 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. PlayStation One Lower Case Replacement, Upper Case: step 1, image 1 of 1
      • Remove all cables plugged into the PlayStation.
      Ask FixBot
    2. PlayStation One Lower Case Replacement: step 2, image 1 of 2 PlayStation One Lower Case Replacement: step 2, image 2 of 2
      • Flip over the PlayStation and remove the six screws from the bottom.
      Ask FixBot
    3. PlayStation One Lower Case Replacement: step 3, image 1 of 1
      • Flip the PlayStation back.
      • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
      Ask FixBot
    4. PlayStation One Lower Case Replacement: step 4, image 1 of 2 PlayStation One Lower Case Replacement: step 4, image 2 of 2
      • Lift up and remove the upper case.
      Ask FixBot
    1. PlayStation One Lower Case Replacement, Laser Assembly: step 5, image 1 of 3 PlayStation One Lower Case Replacement, Laser Assembly: step 5, image 2 of 3 PlayStation One Lower Case Replacement, Laser Assembly: step 5, image 3 of 3
      • Disconnect the cables from the PSone’s board.
      • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
      Ask FixBot
    1. PlayStation One Lower Case Replacement, Mother Board: step 6, image 1 of 2 PlayStation One Lower Case Replacement, Mother Board: step 6, image 2 of 2
      • remove the metal plate
      Ask FixBot
    2. PlayStation One Lower Case Replacement: step 7, image 1 of 3 PlayStation One Lower Case Replacement: step 7, image 2 of 3 PlayStation One Lower Case Replacement: step 7, image 3 of 3
      • remove the mother board by lifting the back.
      • if you're having a hard time removing it, use your nail and lift the second controller port.
      Ask FixBot
    1. PlayStation One Lower Case Replacement, Lower Case: step 8, image 1 of 2 PlayStation One Lower Case Replacement, Lower Case: step 8, image 2 of 2
      • Remove the metal case.
      Ask FixBot
5 other people completed this guide.
Author
with
Marjorie
2,493 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 156
All Time: 6,387
