Tools
Solder and Desolder Kit$115.00
Introduction
Go to step 1 ↓The USB is an important part of the PlayStation Move controller. This guide will help you to remove and replace.
Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
At the end of the circuit board, you should see a small silver connector port (this is the USB).
Using a soldering iron, carefully desolder the port from the board. For help with desoldering, please reference this guide: How To Solder and Desolder Connections
2 other people completed this guide.
