Up to 20% off select tools
PlayStation Move Motherboard Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
96
All Time:
2,696
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a faulty Playstation Move Motherboard.
    1. PlayStation Move Motherboard Replacement, Battery: step 1, image 1 of 3 PlayStation Move Motherboard Replacement, Battery: step 1, image 2 of 3 PlayStation Move Motherboard Replacement, Battery: step 1, image 3 of 3
      • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
      Ask FixBot
    2. PlayStation Move Motherboard Replacement: step 2, image 1 of 2 PlayStation Move Motherboard Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool at the indent.
      • Gently use a forward and backward motion to safely pop open the cover.
      • Using your hands to further pull it apart.
      Ask FixBot
    3. PlayStation Move Motherboard Replacement: step 3, image 1 of 2 PlayStation Move Motherboard Replacement: step 3, image 2 of 2
      • Once the device is opened, lift the battery out of the black plastic holder.
      • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
      Ask FixBot
    4. PlayStation Move Motherboard Replacement: step 4, image 1 of 3 PlayStation Move Motherboard Replacement: step 4, image 2 of 3 PlayStation Move Motherboard Replacement: step 4, image 3 of 3
      • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
      • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
      Ask FixBot
    5. PlayStation Move Motherboard Replacement: step 5, image 1 of 2 PlayStation Move Motherboard Replacement: step 5, image 2 of 2
      • Gently pull out the small grey cylindrical piece (vibrator).
      • Removing this piece makes it easier to access the wire connection of the battery and remove it.
      Ask FixBot
    6. PlayStation Move Motherboard Replacement: step 6, image 1 of 2 PlayStation Move Motherboard Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
      Ask FixBot
    7. PlayStation Move Motherboard Replacement: step 7, image 1 of 3 PlayStation Move Motherboard Replacement: step 7, image 2 of 3 PlayStation Move Motherboard Replacement: step 7, image 3 of 3
      • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
      • Remove by squeezing the inner plastic frame, lift and pull it towards you.
      • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
      Ask FixBot
    8. PlayStation Move Motherboard Replacement: step 8, image 1 of 2 PlayStation Move Motherboard Replacement: step 8, image 2 of 2
      • Gently pull on the white piece connecting the battery and the connector.
      Ask FixBot
    1. PlayStation Move Motherboard Replacement, Motherboard: step 9, image 1 of 3 PlayStation Move Motherboard Replacement, Motherboard: step 9, image 2 of 3 PlayStation Move Motherboard Replacement, Motherboard: step 9, image 3 of 3
      • Remove the five 1.2 mm screws from upper portion of the controller.
      • If you are replacing the trigger button, continue to step 13.
      Ask FixBot
    2. PlayStation Move Motherboard Replacement: step 10, image 1 of 2 PlayStation Move Motherboard Replacement: step 10, image 2 of 2
      • Remove the two 1.2mm Phillips #1 screws.
      Ask FixBot
    3. PlayStation Move Motherboard Replacement: step 11, image 1 of 3 PlayStation Move Motherboard Replacement: step 11, image 2 of 3 PlayStation Move Motherboard Replacement: step 11, image 3 of 3
      • Cautiously remove the circular white piece at the top without removing the LED inside.
      Ask FixBot
    4. PlayStation Move Motherboard Replacement: step 12, image 1 of 3 PlayStation Move Motherboard Replacement: step 12, image 2 of 3 PlayStation Move Motherboard Replacement: step 12, image 3 of 3
      • Remove the blue strip that is connected to the trigger button from the motherboard.
      • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
      Ask FixBot
    5. PlayStation Move Motherboard Replacement: step 13, image 1 of 2 PlayStation Move Motherboard Replacement: step 13, image 2 of 2
      • Remove the trigger button from the controller.
      Ask FixBot
    6. PlayStation Move Motherboard Replacement: step 14, image 1 of 3 PlayStation Move Motherboard Replacement: step 14, image 2 of 3 PlayStation Move Motherboard Replacement: step 14, image 3 of 3
      • Remove the LED light by removing the white strip.
      • If you are replacing the LED light, continue to Step 17.
      Ask FixBot
    7. PlayStation Move Motherboard Replacement: step 15, image 1 of 2 PlayStation Move Motherboard Replacement: step 15, image 2 of 2
      • Remove the motherboard from the plastic case.
      Ask FixBot
Author
with
Destiny Jenkins
175 Reputation
1 Guide authored
USF Tampa, Team 3-3, Passmore Fall 2016 Member of USF Tampa, Team 3-3, Passmore Fall 2016
USFT-PASSMORE-F16S3G3
4 Members
48 Guides authored
2 Guide Comments
Where does one obtain a replacement motherboard?
Tekkromancer - Reply Share
my controllers are also dying anyone know where to get a replacement board? I live in Canada
Jin - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 96
All Time: 2,696
