Up to 20% off select tools
PlayStation Move LED Light Replacement
Views: 6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
116
All Time:
5,976
Comments: 9
4 comments on steps, 5 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 35 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the LED light on the Playstation Move
    1. PlayStation Move LED Light Replacement, Battery: step 1, image 1 of 3 PlayStation Move LED Light Replacement, Battery: step 1, image 2 of 3 PlayStation Move LED Light Replacement, Battery: step 1, image 3 of 3
      • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
      Ask FixBot
    2. PlayStation Move LED Light Replacement: step 2, image 1 of 2 PlayStation Move LED Light Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool at the indent.
      • Gently use a forward and backward motion to safely pop open the cover.
      • Using your hands to further pull it apart.
      Ask FixBot
    3. PlayStation Move LED Light Replacement: step 3, image 1 of 2 PlayStation Move LED Light Replacement: step 3, image 2 of 2
      • Once the device is opened, lift the battery out of the black plastic holder.
      • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
      Ask FixBot
    4. PlayStation Move LED Light Replacement: step 4, image 1 of 3 PlayStation Move LED Light Replacement: step 4, image 2 of 3 PlayStation Move LED Light Replacement: step 4, image 3 of 3
      • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
      • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
      Ask FixBot
    5. PlayStation Move LED Light Replacement: step 5, image 1 of 2 PlayStation Move LED Light Replacement: step 5, image 2 of 2
      • Gently pull out the small grey cylindrical piece (vibrator).
      • Removing this piece makes it easier to access the wire connection of the battery and remove it.
      Ask FixBot
    6. PlayStation Move LED Light Replacement: step 6, image 1 of 2 PlayStation Move LED Light Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
      Ask FixBot
    7. PlayStation Move LED Light Replacement: step 7, image 1 of 3 PlayStation Move LED Light Replacement: step 7, image 2 of 3 PlayStation Move LED Light Replacement: step 7, image 3 of 3
      • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
      • Remove by squeezing the inner plastic frame, lift and pull it towards you.
      • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
      Ask FixBot
    8. PlayStation Move LED Light Replacement: step 8, image 1 of 2 PlayStation Move LED Light Replacement: step 8, image 2 of 2
      • Gently pull on the white piece connecting the battery and the connector.
      Ask FixBot
    1. PlayStation Move LED Light Replacement, Motherboard: step 9, image 1 of 3 PlayStation Move LED Light Replacement, Motherboard: step 9, image 2 of 3 PlayStation Move LED Light Replacement, Motherboard: step 9, image 3 of 3
      • Remove the five 1.2 mm screws from upper portion of the controller.
      • If you are replacing the trigger button, continue to step 13.
      Ask FixBot
    2. PlayStation Move LED Light Replacement: step 10, image 1 of 2 PlayStation Move LED Light Replacement: step 10, image 2 of 2
      • Remove the two 1.2mm Phillips #1 screws.
      Ask FixBot
    3. PlayStation Move LED Light Replacement: step 11, image 1 of 3 PlayStation Move LED Light Replacement: step 11, image 2 of 3 PlayStation Move LED Light Replacement: step 11, image 3 of 3
      • Cautiously remove the circular white piece at the top without removing the LED inside.
      Ask FixBot
    4. PlayStation Move LED Light Replacement: step 12, image 1 of 3 PlayStation Move LED Light Replacement: step 12, image 2 of 3 PlayStation Move LED Light Replacement: step 12, image 3 of 3
      • Remove the blue strip that is connected to the trigger button from the motherboard.
      • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
      Ask FixBot
    5. PlayStation Move LED Light Replacement: step 13, image 1 of 2 PlayStation Move LED Light Replacement: step 13, image 2 of 2
      • Remove the trigger button from the controller.
      Ask FixBot
    6. PlayStation Move LED Light Replacement: step 14, image 1 of 3 PlayStation Move LED Light Replacement: step 14, image 2 of 3 PlayStation Move LED Light Replacement: step 14, image 3 of 3
      • Remove the LED light by removing the white strip.
      • If you are replacing the LED light, continue to Step 17.
      Ask FixBot
    7. PlayStation Move LED Light Replacement: step 15, image 1 of 2 PlayStation Move LED Light Replacement: step 15, image 2 of 2
      • Remove the motherboard from the plastic case.
      Ask FixBot
    1. PlayStation Move LED Light Replacement, LED Light: step 16, image 1 of 2 PlayStation Move LED Light Replacement, LED Light: step 16, image 2 of 2
      Buy
      • Insert tweezers between the LED case and the LED clear plastic cover.
      • Lift the edge of the LED clear cover clip to be able to remove the cover.
      • Repeat the previous step to the other side.
      • Remove the LED cover.
      Ask FixBot
    2. PlayStation Move LED Light Replacement: step 17, image 1 of 2 PlayStation Move LED Light Replacement: step 17, image 2 of 2
      • Remove the LED board using a blue opening tool to lift the board.
      • After the board is loose, remove the LED board.
      Ask FixBot
2 other people completed this guide.
Author
with
Maritza Martinez
155 Reputation
1 Guide authored
USF Tampa, Team 3-3, Passmore Fall 2016 Member of USF Tampa, Team 3-3, Passmore Fall 2016
USFT-PASSMORE-F16S3G3
4 Members
48 Guides authored
5 Guide Comments
Okay, going to try this. Do I have to solder the white strip back onto the board?
randallrigdonjr - Reply Share
did you ever get this done? need to know the same.
[deleted] - Reply Share
très clair, mais où trouver une led ? et en enlevant le cable de la led, il faut le dessourder, non ?
Pierrot - Reply Share
This is BEYOND useless without the information as to where to get the LED unit itself. It's not a standard LED board I can find anywhere.
Also, on the PS3 Move controller the cable from the main board to the LED is soldered both ends and doesn't simply lift away from the circuit.
As to the "beyond useless" comment, this isn't meant to be directed towards the kind people who have spent their time to help others with their knowledge and, their LED cable may have simply lifted away from the board if the Move controller was the later PS4 model, I don't know, I haven't pulled a PS4 Move controller apart (yet).
The guide however would be so much better with that one tiny bit of information, where can I find the LED module and the 1039 number on the LED board itself is of no help in my search.
I stripped my controller down before I found the link to this article (qualifications in electronics), my main need is identifying the faulty LED module so I can replace it.
Leo Anon - Reply Share
Sorry, how do I reconnect the white cable I've just cut away from the circuit board solder joints as you've done?
Butchers!
SERIOUSLY??
No, I'm NOT stupid enough to cut cables and magically think they reconnect using the reverse disassembly instructions as suggested (just poke them in like a magician and they magically connect themselves, if only). Someone needs to rethink their idea of an article to "HELP" people.
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 116
All Time: 5,976
