Up to 20% off select tools
PlayStation Classic Controller Port Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
21
Past 30 Days:
99
All Time:
2,912
Comments: 3
3 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the USB controller ports on the front of the PlayStation Classic video game console.
    1. PlayStation Classic Controller Port Replacement, Motherboard: step 1, image 1 of 1
      • Flip the console so its back is facing up.
      Ask FixBot
    2. PlayStation Classic Controller Port Replacement: step 2, image 1 of 1
      • Remove the five 8mm screws using the Phillips #00 screwdriver.
      • Make sure to keep your screws together in a secure location to avoid misplacement.
      Ask FixBot
    3. PlayStation Classic Controller Port Replacement: step 3, image 1 of 3 PlayStation Classic Controller Port Replacement: step 3, image 2 of 3 PlayStation Classic Controller Port Replacement: step 3, image 3 of 3
      • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
      Ask FixBot
    4. PlayStation Classic Controller Port Replacement: step 4, image 1 of 1
      • Unscrew the motherboard's four 6mm screws with the Phillips #00 screwdriver.
      • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
      • Keep track of your screws once they are removed.
      Ask FixBot
    5. PlayStation Classic Controller Port Replacement: step 5, image 1 of 3 PlayStation Classic Controller Port Replacement: step 5, image 2 of 3 PlayStation Classic Controller Port Replacement: step 5, image 3 of 3
      • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
      Ask FixBot
    6. PlayStation Classic Controller Port Replacement: step 6, image 1 of 3 PlayStation Classic Controller Port Replacement: step 6, image 2 of 3 PlayStation Classic Controller Port Replacement: step 6, image 3 of 3
      • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
      • Pull the metal casing off the motherboard.
      • Remember to be gentle when handling the motherboard.
      Ask FixBot
    1. PlayStation Classic Controller Port Replacement, Controller Port: step 7, image 1 of 2 PlayStation Classic Controller Port Replacement, Controller Port: step 7, image 2 of 2
      • Identify the damaged or faulty controller port and simply use your fingers to remove.
      Ask FixBot
Author
with
Maxwell Webb
709 Reputation
5 Guides authored
Cal Poly, Team S2-G8, Maness Spring 2019 Member of Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 99
All Time: 2,912
