PlayStation 5 Slim Disc Drive Replacement
Views: 36K
View statistics:
Past 24 Hours:
48
Past 7 Days:
316
Past 30 Days:
1,404
All Time:
35,977
Comments: 14
4 comments on steps, 10 guide comments.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Introduction
Go to step 1 ↓
Follow this guide to replace a broken or faulty disc drive in your PlayStation 5 Slim. You can also use this guide to install a disc drive if your PlayStation doesn't have one, but you'll need a new console cover that will fit over the drive.
If you're having issues playing disc-based games, Blu-rays, or DVDs, you may need to replace your disc drive.
An internet connection is required to set up and pair your new disc drive.
Parts
    1. PlayStation 5 Slim Disc Drive Replacement, Prepare your PlayStation for disassembly: step 1, image 1 of 3 PlayStation 5 Slim Disc Drive Replacement, Prepare your PlayStation for disassembly: step 1, image 2 of 3 PlayStation 5 Slim Disc Drive Replacement, Prepare your PlayStation for disassembly: step 1, image 3 of 3
      • Before starting your repair:
      • Shut down your console and unplug all cables and accessories.
      • Remove any stands supporting your device and lay it down.
      Ask FixBot
    1. Careful: step 2 is sourced from a guide that's marked as in-progress.
      PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive cover: step 2, image 1 of 3 PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive cover: step 2, image 2 of 3 PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive cover: step 2, image 3 of 3
      • The disc drive cover is secured with hooks along the back edge and clips along the front edge.
      • Firmly pull up the front edge of the disc drive cover to release the clips.
      • You'll hear distinct "pops" as the clips release.
      • Remove the cover.
      • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the three clips.
      Ask FixBot
    1. Careful: step 3 is sourced from a guide that's marked as in-progress.
      PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive: step 3, image 1 of 3 PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive: step 3, image 2 of 3 PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive: step 3, image 3 of 3
      • Use the cutout on the bottom right corner of the disc drive to lift its right edge and disconnect it.
      • Remove the disc drive.
      Ask FixBot
    1. PlayStation 5 Slim Disc Drive Replacement, Install the disc drive: step 4, image 1 of 3 PlayStation 5 Slim Disc Drive Replacement, Install the disc drive: step 4, image 2 of 3 PlayStation 5 Slim Disc Drive Replacement, Install the disc drive: step 4, image 3 of 3
      Ask FixBot
19 other people completed this guide.
Spencer Day
207,725 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
10 Guide Comments
Spencer, thank you for all your efforts in making this task manageable to all of us rtr novices!
Deeno
Deeno - Reply Share
once a disc drive has been paired with a system , can we use the same disc drive on another ps5 system ?
maniaque37 - Reply Share
Yes you can! You should be prompted to register the drive with your device, which will require an internet connection.
Spencer Day - Reply Share
Where can I get a new disk drive in Australia?
Albert einstein - Reply Share
Also. Is it the same drive as you would add to the digital version
Past 24 Hours: 48
Past 7 Days: 316
Past 30 Days: 1,404
All Time: 35,977
