PlayStation 5 Pro Power Supply Replacement
  1. PlayStation 5 Pro Power Supply Replacement, Before you begin: step 1, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Before you begin: step 1, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Before you begin: step 1, image 3 of 3
    • Before starting your repair:
    • Shut down your PlayStation and unplug all cables and accessories.
    • Remove any stands supporting your console and lay it down so the right side is facing up.
    Ask FixBot
  2. PlayStation 5 Pro Power Supply Replacement, Remove the console covers: step 2, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the console covers: step 2, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the console covers: step 2, image 3 of 3
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
    Ask FixBot
  3. PlayStation 5 Pro Power Supply Replacement: step 3, image 1 of 3 PlayStation 5 Pro Power Supply Replacement: step 3, image 2 of 3 PlayStation 5 Pro Power Supply Replacement: step 3, image 3 of 3
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
    Ask FixBot
  4. PlayStation 5 Pro Power Supply Replacement, Remove the power supply screws: step 4, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Remove the power supply screws: step 4, image 2 of 2
    • Use a T8 Torx Security screwdriver to remove the two 21.5 mm‑long screws securing the power supply.
    • Flip your PlayStation over.
    Ask FixBot
  5. PlayStation 5 Pro Power Supply Replacement, Remove the expansion slot cover screw: step 5, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Remove the expansion slot cover screw: step 5, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
    Ask FixBot
  6. PlayStation 5 Pro Power Supply Replacement, Remove the expansion slot cover: step 6, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the expansion slot cover: step 6, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the expansion slot cover: step 6, image 3 of 3
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
    Ask FixBot
  7. PlayStation 5 Pro Power Supply Replacement, Remove the fan cables cover: step 7, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the fan cables cover: step 7, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the fan cables cover: step 7, image 3 of 3
    Tesa 61395 Tape
    $8.95
    Buy
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
    Ask FixBot
  8. PlayStation 5 Pro Power Supply Replacement, Free the fan cables: step 8, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Free the fan cables: step 8, image 2 of 2
    • Gently pull the fan cables out from under their plastic clip on the frame.
    Ask FixBot
  9. PlayStation 5 Pro Power Supply Replacement, Disconnect the fan: step 9, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Disconnect the fan: step 9, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Disconnect the fan: step 9, image 3 of 3
    • Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
    Ask FixBot
  10. PlayStation 5 Pro Power Supply Replacement, Remove the fan screws: step 10, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Remove the fan screws: step 10, image 2 of 2
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.7 mm‑long screw
    • Two 21.5 mm‑long screws
    • One 11.5 mm‑long screw
    Ask FixBot
  11. PlayStation 5 Pro Power Supply Replacement, Remove the fan: step 11, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Remove the fan: step 11, image 2 of 2
    • Use your fingers to grab the fan by its vents and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
    Ask FixBot
  12. PlayStation 5 Pro Power Supply Replacement, Peel up the tamper evident sticker: step 12, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Peel up the tamper evident sticker: step 12, image 2 of 2
    Ask FixBot
  13. PlayStation 5 Pro Power Supply Replacement, Remove the fan grille: step 13, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the fan grille: step 13, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the fan grille: step 13, image 3 of 3
    • Use your fingers to unclip and remove the plastic grille near the fan recess.
    Ask FixBot
  14. PlayStation 5 Pro Power Supply Replacement, Remove the right‑side inner shell screws: step 14, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Remove the right‑side inner shell screws: step 14, image 2 of 2
    • Use a T8 Torx Security screwdriver to remove the 10 screws securing the right‑side inner shell:
    • Four 18.8 mm‑long screws
    • Two 18.6 mm‑long screws
    • Four 31.7 mm‑long screws
    Ask FixBot
  15. PlayStation 5 Pro Power Supply Replacement, Remove the right‑side inner shell: step 15, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Remove the right‑side inner shell: step 15, image 2 of 2
    • Lift the right‑side inner shell straight up and remove it.
    Ask FixBot
  16. PlayStation 5 Pro Power Supply Replacement, Disconnect the CMOS board: step 16, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Disconnect the CMOS board: step 16, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Disconnect the CMOS board: step 16, image 3 of 3
    • Use a pair of angled tweezers to firmly grip the sides of the CMOS board connector, holding the tweezers as close to the connector as possible to get a good grip.
    • Pull the connector straight up and out of its socket to disconnect it.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    Ask FixBot
  17. PlayStation 5 Pro Power Supply Replacement, Remove the CMOS board: step 17, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the CMOS board: step 17, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the CMOS board: step 17, image 3 of 3
    • Use your fingers to lift the CMOS board off the small metal nubs and pull it toward the center of your console to remove it.
    • If your new board doesn't come with a cable, transfer the original cable to your replacement board.
    Ask FixBot
  18. PlayStation 5 Pro Power Supply Replacement, Disconnect the antenna cables: step 18, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Disconnect the antenna cables: step 18, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Disconnect the antenna cables: step 18, image 3 of 3
    • Insert a spudger under the metal neck of one of the antenna cable's coaxial connectors and lift straight up to disconnect it.
    • Repeat the process to disconnect the other antenna cable.
    • Use the markings on the board to reconnect the antenna cables to the correct sockets—connect the blue cable to the socket marked RB and the white cable to the one marked RW.
    • To reconnect a cable, hold the metal connector head over its socket and press down with the flat end of a spudger until the connector snaps into place. Don't try to force the connector into place. If you're having trouble, reposition the connector and try again.
    Ask FixBot
  19. PlayStation 5 Pro Power Supply Replacement: step 19, image 1 of 3 PlayStation 5 Pro Power Supply Replacement: step 19, image 2 of 3 PlayStation 5 Pro Power Supply Replacement: step 19, image 3 of 3
    • Use the point of a spudger to flip up the small piece of white tape securing the antenna cables to the metal shield.
    Ask FixBot
  20. PlayStation 5 Pro Power Supply Replacement, Move the antenna cables: step 20, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Move the antenna cables: step 20, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Move the antenna cables: step 20, image 3 of 3
    • Use your fingers to de‑route the antenna cables from their clips on the metal shield.
    • Move the antenna cables over the side of your PlayStation so they're out of the way.
    Ask FixBot
  21. PlayStation 5 Pro Power Supply Replacement, Pry up the heat sink: step 21, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Pry up the heat sink: step 21, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Pry up the heat sink: step 21, image 3 of 3
    • Thermal paste bonds the bottom heat sink fins (closest to the power button) to the metal shield. Depending on the age of your device and condition of the thermal paste, separating the heat sink may take some force.
    • Insert the flat end of a spudger under the bend in the copper pipes, near the heat sink's bottom edge.
    • Use your spudger to pry up the heat sink, applying steady pressure to separate it from the thermal paste.
    • If the heat sink doesn't fully separate, use your spudger to pry up the bottom edge on the other side of the metal fins.
    Ask FixBot
  22. PlayStation 5 Pro Power Supply Replacement, Remove the heat sink: step 22, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Remove the heat sink: step 22, image 2 of 2
    • Grip the heat sink by its copper pipes and remove it.
    • Don't grip the sharp, metal fins on the heat sink.
    • Before removing any of the old thermal paste, note the location and quantity of thermal paste on the metal shield. This way you'll know how much to use when replacing it.
    • Use the flat end of a spudger to scrape up and remove as much of the old thermal paste as possible.
    • Remove all the remaining thermal paste and its residue with high‑concentration (>90%) isopropyl alcohol and a microfiber cloth.
    • Apply new thermal paste where the old paste was.
    • Firmly push the heat sink into place.
    Ask FixBot
  23. PlayStation 5 Pro Power Supply Replacement, Remove the main board assembly screws: step 23, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the main board assembly screws: step 23, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the main board assembly screws: step 23, image 3 of 3
    • Use a T8 Torx Security screwdriver to remove the six screws:
    • One 11.5 mm‑long black screw securing the main board assembly
    • One 28.7 mm‑long screw securing the interconnect cable cover
    • Four 7.5 mm‑long screws securing the interconnect cable cover
    Ask FixBot
  24. PlayStation 5 Pro Power Supply Replacement, Remove the interconnect cable cover: step 24, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Remove the interconnect cable cover: step 24, image 2 of 2
    • Remove the interconnect cable cover.
    Ask FixBot
  25. PlayStation 5 Pro Power Supply Replacement, Disconnect the interconnect cable: step 25, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Disconnect the interconnect cable: step 25, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Disconnect the interconnect cable: step 25, image 3 of 3
    • Use the flat end of a spudger to push down the metal bar on the interconnect cable socket.
    • With the metal bar held down, use your fingers or tweezers to grip the plastic pull tab and slide the cable straight out of its socket.
    • During reassembly, insert the interconnect cable into the socket until it snaps into place.
    Ask FixBot
  26. PlayStation 5 Pro Power Supply Replacement, Lift the main board assembly: step 26, image 1 of 2 PlayStation 5 Pro Power Supply Replacement, Lift the main board assembly: step 26, image 2 of 2
    • The power supply is connected to the bottom of the main board assembly by metal prongs that plug into the bottom left corner.
    • Lift the bottom left corner of the main board assembly off its gray plastic post. Keep the assembly lifted for the next step.
    • Your PlayStation's plastic housing will likely flex while lifting the assembly.
    Ask FixBot
  27. PlayStation 5 Pro Power Supply Replacement, Detach the power supply: step 27, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Detach the power supply: step 27, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Detach the power supply: step 27, image 3 of 3
    • Keep the main board assembly raised with one hand.
    • With your free hand, insert your finger between the assembly and power supply.
    • Push down on the power supply and lift the assembly to separate them.
    • It'll take a significant amount of force to separate the two.
    • During reassembly, press down firmly on the bottom left corner of the main board assembly to fully connect it to the power supply.
    Ask FixBot
  28. PlayStation 5 Pro Power Supply Replacement, Remove the main board assembly: step 28, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the main board assembly: step 28, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the main board assembly: step 28, image 3 of 3
    • Do not grab the main board assembly by the copper heat pipes or its fins, as they can easily be damaged.
    • Firmly secure the plastic housing with one hand.
    • With your free hand, grab the upper edge of the main board assembly and lift it out of the plastic housing.
    • Make sure the interconnect cable doesn't get stuck under the main board assembly when lowering it into place.
    • Lower the assembly into its recess so its prongs go into their socket on the power supply and the two cutouts go over their alignment posts.
    Ask FixBot
  29. PlayStation 5 Pro Power Supply Replacement, Remove the power supply: step 29, image 1 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the power supply: step 29, image 2 of 3 PlayStation 5 Pro Power Supply Replacement, Remove the power supply: step 29, image 3 of 3
    • Lift the left edge of the power supply and remove it.
    • Insert the power port into its cutout on the back of your PlayStation.
    • Lower the power supply into its recess, making sure the cutout on the bottom left corner goes over its plastic post.
    Ask FixBot
Spencer Day
196,311 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,230 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 92
Past 30 Days: 474
All Time: 4,085
