PlayStation 5 Pro Fan Replacement
    1. PlayStation 5 Pro Fan Replacement, Before you begin: step 1, image 1 of 3 PlayStation 5 Pro Fan Replacement, Before you begin: step 1, image 2 of 3 PlayStation 5 Pro Fan Replacement, Before you begin: step 1, image 3 of 3
      • Before starting your repair:
      • Shut down your PlayStation and unplug all cables and accessories.
      • Remove any stands supporting your console and lay it down so the right side is facing up.
      Ask FixBot
    1. PlayStation 5 Pro Fan Replacement, Remove the fan and SSD cover: step 2, image 1 of 3 PlayStation 5 Pro Fan Replacement, Remove the fan and SSD cover: step 2, image 2 of 3 PlayStation 5 Pro Fan Replacement, Remove the fan and SSD cover: step 2, image 3 of 3
      • The cover is secured with hooks along the back edge and clips along the front edge.
      • Firmly pull up the front edge of the smaller, upper cover to release the clips.
      • You'll hear distinct "pops" as the clips disengage.
      • Remove the cover.
      • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the two clips.
      Ask FixBot
    1. PlayStation 5 Pro Fan Replacement, Remove the fan cables cover: step 3, image 1 of 3 PlayStation 5 Pro Fan Replacement, Remove the fan cables cover: step 3, image 2 of 3 PlayStation 5 Pro Fan Replacement, Remove the fan cables cover: step 3, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Use your fingers to remove the plastic cover hiding the fan cables connector.
      • The cover is secured with light adhesive.
      • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
      Ask FixBot
    2. PlayStation 5 Pro Fan Replacement, Free the fan cables: step 4, image 1 of 2 PlayStation 5 Pro Fan Replacement, Free the fan cables: step 4, image 2 of 2
      • Gently pull the fan cables out from under their plastic clip on the frame.
      Ask FixBot
    3. PlayStation 5 Pro Fan Replacement, Disconnect the fan: step 5, image 1 of 2 PlayStation 5 Pro Fan Replacement, Disconnect the fan: step 5, image 2 of 2
      • Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
      • If you're having trouble, grip the cables just above the connector head and gently pull.
      • During reassembly, align the connector over its socket and push down on the edges with a clean fingernail or the flat end of a spudger until it slides fully into its socket.
      Ask FixBot
    4. PlayStation 5 Pro Fan Replacement, Remove the fan screws: step 6, image 1 of 2 PlayStation 5 Pro Fan Replacement, Remove the fan screws: step 6, image 2 of 2
      FixMat
      $36.95
      Buy
      • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
      • One 31.7 mm‑long screw
      • Two 21.5 mm‑long screws
      • One 11.5 mm‑long screw
      Ask FixBot
    5. PlayStation 5 Pro Fan Replacement, Remove the fan: step 7, image 1 of 2 PlayStation 5 Pro Fan Replacement, Remove the fan: step 7, image 2 of 2
      • Use your fingers to grab the fan by its vents and lift it straight up to remove it.
      • If you're using this guide to clean your fan, use compressed air and a clean cloth to remove any dust or dirt.
      • During reassembly, insert the fan so its cables are near their connector.
      Ask FixBot
3 other people completed this guide.
Spencer Day
201,076 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 24
Past 7 Days: 171
Past 30 Days: 652
All Time: 6,980
