Introduction
Follow this guide to replace the CMOS battery (aka coin cell battery or RTC battery) in your PlayStation 5 Pro.
If your PlayStation's date and time settings are out of sync or not saving, you may need to replace the CMOS battery.
Shut down your PlayStation and unplug all cables and accessories.
Remove any stands supporting your console and lay it down so the right side is facing up.
Firmly pull up the front edge of the larger, lower cover to release the clips.
Tool used on this step:Flathead 4 mm Screwdriver$1.99
Use a Phillips screwdriver to fully loosen the captive screw securing the CMOS battery cover (the screw will stay in the cover—don't try to remove it).
Use your fingers to grip the cover's screw and remove the cover.
Use the point of a spudger to gently pry up the CMOS battery.
Remove the CMOS battery.
2 other people completed this guide.
