Up to 20% off select tools
PlayStation 5 Fan Replacement
Views: 391K
View statistics:
Past 24 Hours:
379
Past 7 Days:
2,878
Past 30 Days:
14,674
All Time:
390,896
Comments: 49
37 comments on steps, 12 guide comments.
Go to guide comments
Completed: 59
59 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
  • PlayStation 5 Fan
    4.8
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a faulty cooling fan in a PlayStation 5. You can also follow this guide to remove a dusty or dirty fan to clean it out.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Video Overview
    1. PlayStation 5 Fan Replacement, Remove the stand screw: step 1, image 1 of 1
      • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
      • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
      • Work on a flat surface to prevent your PlayStation from falling over.
      • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
      Ask FixBot
    2. PlayStation 5 Fan Replacement, Remove the vertical stand: step 2, image 1 of 2 PlayStation 5 Fan Replacement, Remove the vertical stand: step 2, image 2 of 2
      • Lift straight up to remove the stand.
      Ask FixBot
    3. PlayStation 5 Fan Replacement, Store the stand screw: step 3, image 1 of 2 PlayStation 5 Fan Replacement, Store the stand screw: step 3, image 2 of 2
      • Insert the screw into the cubby on the bottom of the stand.
      Ask FixBot
    4. PlayStation 5 Fan Replacement, Cap the screw hole: step 4, image 1 of 3 PlayStation 5 Fan Replacement, Cap the screw hole: step 4, image 2 of 3 PlayStation 5 Fan Replacement, Cap the screw hole: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
      • Use your finger to press the cap into the screw hole.
      Ask FixBot
    5. PlayStation 5 Fan Replacement, Close the cubby: step 5, image 1 of 3 PlayStation 5 Fan Replacement, Close the cubby: step 5, image 2 of 3 PlayStation 5 Fan Replacement, Close the cubby: step 5, image 3 of 3
      • Twist the stand counterclockwise to close the cubby.
      Ask FixBot
    6. PlayStation 5 Fan Replacement, Remove the horizontal stand: step 6, image 1 of 2 PlayStation 5 Fan Replacement, Remove the horizontal stand: step 6, image 2 of 2
      • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
      • Lift the stand straight up to remove it.
      Ask FixBot
    1. PlayStation 5 Fan Replacement, Remove the right faceplate: step 7, image 1 of 3 PlayStation 5 Fan Replacement, Remove the right faceplate: step 7, image 2 of 3 PlayStation 5 Fan Replacement, Remove the right faceplate: step 7, image 3 of 3
      • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
      • Lift up the corner of the faceplate to unclip it from the case.
      Ask FixBot
    2. PlayStation 5 Fan Replacement: step 8, image 1 of 2 PlayStation 5 Fan Replacement: step 8, image 2 of 2
      • While lifting up the corner, slide the faceplate towards the bottom of the device.
      • Remove the right faceplate.
      Ask FixBot
    3. PlayStation 5 Fan Replacement, Pry up the grille: step 9, image 1 of 3 PlayStation 5 Fan Replacement, Pry up the grille: step 9, image 2 of 3 PlayStation 5 Fan Replacement, Pry up the grille: step 9, image 3 of 3
      • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
      • Lift up with the spudger to pry the grille away from the case.
      Ask FixBot
    4. PlayStation 5 Fan Replacement, Remove the grille: step 10, image 1 of 2 PlayStation 5 Fan Replacement, Remove the grille: step 10, image 2 of 2
      • Lift the grille away from the case to remove it.
      Ask FixBot
    5. PlayStation 5 Fan Replacement, Remove the fan shroud screws: step 11, image 1 of 1
      Magnetic Project Mat
      $16.96
      Buy
      • Use a TR9 Torx Security driver to remove the four screws securing the fan shroud to the case:
      • Two 23.3 mm-long screws
      • One 11.4 mm-long screw
      • One 31 mm-long screw
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      Ask FixBot
    6. PlayStation 5 Fan Replacement, Remove the fan shroud: step 12, image 1 of 2 PlayStation 5 Fan Replacement, Remove the fan shroud: step 12, image 2 of 2
      • Lift the fan shroud straight up to remove it.
      Ask FixBot
    7. PlayStation 5 Fan Replacement, Remove the wire cover: step 13, image 1 of 3 PlayStation 5 Fan Replacement, Remove the wire cover: step 13, image 2 of 3 PlayStation 5 Fan Replacement, Remove the wire cover: step 13, image 3 of 3
      • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
      • Pry only on the wire cover, not on the fan wires themselves.
      • Use the spudger to peel up the wire cover until you can grip it with your fingers.
      Ask FixBot
    8. PlayStation 5 Fan Replacement: step 14, image 1 of 3 PlayStation 5 Fan Replacement: step 14, image 2 of 3 PlayStation 5 Fan Replacement: step 14, image 3 of 3
      • Use your fingers to peel off the wire cover.
      Ask FixBot
    9. PlayStation 5 Fan Replacement, Disconnect the fan: step 15, image 1 of 2 PlayStation 5 Fan Replacement, Disconnect the fan: step 15, image 2 of 2
      • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
      • Always pull cables by their connectors and not the wires themselves.
      Ask FixBot
    10. PlayStation 5 Fan Replacement, Remove the fan: step 16, image 1 of 3 PlayStation 5 Fan Replacement, Remove the fan: step 16, image 2 of 3 PlayStation 5 Fan Replacement, Remove the fan: step 16, image 3 of 3
      • Lift the fan up and out of the case to remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
59 other people completed this guide.
Author
with
Robert Boyd
34,047 Reputation
94 Guides authored
12 Guide Comments
Hello, I followed tronix fixs and he used pliers then I used it as well and the yellow part came off and the fan lines broke I don't know what to do since I have been saving up since it came out
Emran - Reply Share
Can I put a 23 blade fan in a system that came with the 1.9a 17 blade fan?
wgeclipse - Reply Share
Did you find out?
Popes - Reply Share
I just did exactly that for a customer (technically it was a 23 blade 2.15A fan) it works great, the fan connector leads are just barely long enough to fit in the channel in a CFI-1215A model though, so careful not to tug too hard after plugging the fan connector and seating the fan in place.
just chris... - Reply Share
Would a fan going bad prevent the PS 5 from turning on?
Frank Garcia - Reply Share
Past 24 Hours: 379
Past 7 Days: 2,878
Past 30 Days: 14,674
All Time: 390,896
