This guide has more recent changes. Switch to the latest unverified version.
PlayStation 5 Faceplates Replacement
    1. PlayStation 5 Faceplates Replacement, Remove the stand screw: step 1, image 1 of 1
      • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
      • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
      • Work on a flat surface to prevent your PlayStation from falling over.
      • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
      Ask FixBot
    2. PlayStation 5 Faceplates Replacement, Remove the vertical stand: step 2, image 1 of 2 PlayStation 5 Faceplates Replacement, Remove the vertical stand: step 2, image 2 of 2
      • Lift straight up to remove the stand.
      Ask FixBot
    3. PlayStation 5 Faceplates Replacement, Store the stand screw: step 3, image 1 of 2 PlayStation 5 Faceplates Replacement, Store the stand screw: step 3, image 2 of 2
      • Insert the screw into the cubby on the bottom of the stand.
      Ask FixBot
    4. PlayStation 5 Faceplates Replacement, Cap the screw hole: step 4, image 1 of 3 PlayStation 5 Faceplates Replacement, Cap the screw hole: step 4, image 2 of 3 PlayStation 5 Faceplates Replacement, Cap the screw hole: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
      • Use your finger to press the cap into the screw hole.
      Ask FixBot
    5. PlayStation 5 Faceplates Replacement, Close the cubby: step 5, image 1 of 3 PlayStation 5 Faceplates Replacement, Close the cubby: step 5, image 2 of 3 PlayStation 5 Faceplates Replacement, Close the cubby: step 5, image 3 of 3
      • Twist the stand counterclockwise to close the cubby.
      Ask FixBot
    6. PlayStation 5 Faceplates Replacement, Remove the horizontal stand: step 6, image 1 of 2 PlayStation 5 Faceplates Replacement, Remove the horizontal stand: step 6, image 2 of 2
      • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
      • Lift the stand straight up to remove it.
      Ask FixBot
    1. PlayStation 5 Faceplates Replacement, Remove the left faceplate: step 7, image 1 of 3 PlayStation 5 Faceplates Replacement, Remove the left faceplate: step 7, image 2 of 3 PlayStation 5 Faceplates Replacement, Remove the left faceplate: step 7, image 3 of 3
      • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
      Ask FixBot
    2. PlayStation 5 Faceplates Replacement: step 8, image 1 of 2 PlayStation 5 Faceplates Replacement: step 8, image 2 of 2
      • While lifting up the corner, slide the faceplate towards the bottom of the device.
      • Remove the left faceplate.
      Ask FixBot
    3. PlayStation 5 Faceplates Replacement, Remove the right faceplate: step 9, image 1 of 3 PlayStation 5 Faceplates Replacement, Remove the right faceplate: step 9, image 2 of 3 PlayStation 5 Faceplates Replacement, Remove the right faceplate: step 9, image 3 of 3
      • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
      • Lift up the corner of the faceplate to unclip it from the case.
      Ask FixBot
    4. PlayStation 5 Faceplates Replacement: step 10, image 1 of 2 PlayStation 5 Faceplates Replacement: step 10, image 2 of 2
      • Remove the right faceplate.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
41 other people completed this guide.
Clay Kim
13,397 Reputation
21 Guides authored
1 Guide Comment
Hello, thanks for the updates
hadi rp - Reply Share
Past 24 Hours: 72
Past 7 Days: 409
Past 30 Days: 1,462
All Time: 45,080
