PlayStation 4 Slim Bottom Cover Replacement
    1. PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: step 1, image 3 of 3
      • Locate the plastic warranty sticker next to the three ports on the side of the console.
      • Remove the warranty sticker by peeling it off with any kind of spudger.
      • Removing the warranty sticker will NOT cause your warranty to be null and void.
      Ask FixBot
    2. PlayStation 4 Slim Bottom Cover Replacement: step 2, image 1 of 2 PlayStation 4 Slim Bottom Cover Replacement: step 2, image 2 of 2
      • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
      Ask FixBot
    3. PlayStation 4 Slim Bottom Cover Replacement: step 3, image 1 of 3 PlayStation 4 Slim Bottom Cover Replacement: step 3, image 2 of 3 PlayStation 4 Slim Bottom Cover Replacement: step 3, image 3 of 3
      • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
      • Pry up on the two corners that are facing you with your fingers.
      • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
      • Remove the bottom cover by sliding it towards the back corners and lifting up.
      Ask FixBot
63 other people completed this guide.
Hernan Rodriguez
4,918 Reputation
3 Guides authored
2 Guide Comments
Wo kann man die Bodenplatte kaufen?
Emre Kaman - Reply Share
Hi hello it's Good
محب علي شاكر - Reply Share
Past 24 Hours: 33
Past 7 Days: 244
Past 30 Days: 1,058
All Time: 76,294
