Up to 20% off select tools
PlayStation 4 Pro Optical Drive Replacement
Views: 143K
View statistics:
Past 24 Hours:
54
Past 7 Days:
287
Past 30 Days:
1,463
All Time:
142,513
Comments: 100
78 comments on steps, 22 guide comments.
Go to guide comments
Completed: 69
69 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide includes the steps necessary to remove the optical drive in the PlayStation 4 Pro. This is one of the last things that is removable in the PS4 Pro, which means that just about everything else has to be removed first. This guide includes a large amount of disassembly, as well as warranty-voiding steps.
    1. PlayStation 4 Pro Optical Drive Replacement, Hard Drive Caddy: step 1, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement, Hard Drive Caddy: step 1, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement, Hard Drive Caddy: step 1, image 3 of 3
      • Flip the console upside down.
      • Use your finger to pull and snap off the plastic cover over the hard drive.
      Ask FixBot
    2. PlayStation 4 Pro Optical Drive Replacement: step 2, image 1 of 2 PlayStation 4 Pro Optical Drive Replacement: step 2, image 2 of 2
      • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
      • Pull the hard drive caddy straight out.
      Ask FixBot
    1. PlayStation 4 Pro Optical Drive Replacement, Power Supply Assembly: step 3, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement, Power Supply Assembly: step 3, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement, Power Supply Assembly: step 3, image 3 of 3
      • Flip the console right side up.
      • Grip the two corners located at the front of the device.
      • Pull upwards until a loud click is heard.
      • This may require a lot of force, so do not be afraid to get a little rough with your console.
      • After both corners detach, slide the cover backwards and lift off.
      Ask FixBot
    2. PlayStation 4 Pro Optical Drive Replacement: step 4, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement: step 4, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement: step 4, image 3 of 3
      • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
      • Two 31mm screws.
      • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
      • Remove the metal plate by pulling it up.
      Ask FixBot
    3. PlayStation 4 Pro Optical Drive Replacement: step 5, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement: step 5, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement: step 5, image 3 of 3
      • Flip the console over so the bottom is facing up.
      • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
      • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
      Ask FixBot
    4. PlayStation 4 Pro Optical Drive Replacement: step 6, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement: step 6, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement: step 6, image 3 of 3
      • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
      • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
      • 7200-series models have 13 additional 4mm screws around the top and right of the metal plate. These screws are are indicated with a triangle. This may apply to other models.
      • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
      Ask FixBot
    5. PlayStation 4 Pro Optical Drive Replacement: step 7, image 1 of 2 PlayStation 4 Pro Optical Drive Replacement: step 7, image 2 of 2
      • Pull the white fan connector straight out of the yellow mount on the motherboard.
      Ask FixBot
    6. PlayStation 4 Pro Optical Drive Replacement: step 8, image 1 of 2 PlayStation 4 Pro Optical Drive Replacement: step 8, image 2 of 2
      • Pull out the five small, blue low profile cables connected to the metal plate.
      • Lift the retaining flap on the ZIF connector of the large ribbon cable.
      • Pull the large ribbon cable from its socket.
      • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
      Ask FixBot
    7. PlayStation 4 Pro Optical Drive Replacement: step 9, image 1 of 1
      • Pull up and remove the metal plate.
      Ask FixBot
    8. PlayStation 4 Pro Optical Drive Replacement: step 10, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement: step 10, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement: step 10, image 3 of 3
      • Flip the console over to continue working on the top side.
      • Pull up on the power supply unit and set it on the console.
      • Be careful not to pull too far, the assembly is still connected at one point.
      • Grip the connector behind the power supply and pull straight out.
      Ask FixBot
    1. PlayStation 4 Pro Optical Drive Replacement, Motherboard: step 11, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement, Motherboard: step 11, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement, Motherboard: step 11, image 3 of 3
      • If you are working on the 7200-series model, this metal plate will have been already removed as part of the removing the larger motherboard plate. You may skip this step if this is the case.
      • Carefully flip the console over so the bottom is facing up.
      • Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol.
      • Use a plastic opening tool to remove the metal plate with the X-like shape.
      Ask FixBot
    2. PlayStation 4 Pro Optical Drive Replacement: step 12, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement: step 12, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement: step 12, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath.
      • For 7200-series models this is instead a S-shaped metal plate with 2 screws.
      • Grip the X-shaped retaining bracket and lift straight up.
      Ask FixBot
    3. PlayStation 4 Pro Optical Drive Replacement: step 13, image 1 of 2 PlayStation 4 Pro Optical Drive Replacement: step 13, image 2 of 2
      • Grip the edge of the motherboard and slowly lift upwards to remove it from the device.
      • For reassembly, use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
      Ask FixBot
    1. PlayStation 4 Pro Optical Drive Replacement, Heat Pipe: step 14, image 1 of 2 PlayStation 4 Pro Optical Drive Replacement, Heat Pipe: step 14, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 6 mm silver screws from the metal plate.
      Ask FixBot
    2. PlayStation 4 Pro Optical Drive Replacement: step 15, image 1 of 2 PlayStation 4 Pro Optical Drive Replacement: step 15, image 2 of 2
      • Lift the metal plate that is connected to the heat pipe straight up to remove it.
      Ask FixBot
    1. PlayStation 4 Pro Optical Drive Replacement, Optical Drive: step 16, image 1 of 3 PlayStation 4 Pro Optical Drive Replacement, Optical Drive: step 16, image 2 of 3 PlayStation 4 Pro Optical Drive Replacement, Optical Drive: step 16, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the four screws.
      • One 30 mm screw.
      • Three 6mm screws.
      • Grab the optical drive and lift up to remove.
      Ask FixBot
69 other people completed this guide.
Author
with
Thomas
4,197 Reputation
5 Guides authored
Cal Poly, Team S21-G5, Livingston Spring 2017 Member of Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 Members
84 Guides authored
22 Guide Comments
I called an “expert” and they said buying a new drive wont work. I would have to buy a whole new mother board as well…
Vince - Reply Share
The PS4 Pro does not have a daughter board attached to the optical drive to match up the optical drive model numbers to like the regular PS4. Where do we find what replacement optical drive to buy? Would it be the most recent BDP-025?
David - Reply Share
I’m currently trying to find a replacement Optical Drive for my Ps4 Pro myself. Apparently, This is really hard to find. Managed to find a used one but the price to me seems a bit high at $123.
Shaquille Moss - Reply Share
Excellent instructions just saved me a lot of dosh. I would recommend using Phillips #00 where #0 is noted however - worked better for me.
Thanks again though!
Marc Butterworh - Reply Share
Forgot to say that I my drive was fine once I fished out the two Switch cartridges my 3 year old had posted in there! Obviously wanted to play Zelda on my PS4 pro - if only.
Past 24 Hours: 54
Past 7 Days: 287
Past 30 Days: 1,463
All Time: 142,513
